AVS › AVS Forum › Video Components › Home Theater Computers › Mfusick's New HTPC Build !!! (Pictures included)
Mfusick's New HTPC Build !!! (Pictures included) - Page 2
post #31 of 180
post #32 of 180
another shot
from under
post #33 of 180
post #34 of 180
post #35 of 180
post #36 of 180
post #37 of 180
If you ever installed plastic fans with the standard screws you know they suck and you have to turn them hard.
Often they strip or create issues.
I used some olive oil from the kitchen on a q-tip to lubricate the fan screws before screwing them into the plastic.
Made installation much easier
post #38 of 180
post #39 of 180
post #40 of 180
post #41 of 180
FRONT USB 3.0 is nice.
post #42 of 180
Case allows me three settings- LOW MEDIUM and HIGH.
I can also turn the fans off.
Each area has controls.
easily disable or adjust speed of any bank of fans. Top of case, Side, Front, HDD or GPU areas...
SWEET !
Not to mention high quality buttons.
post #43 of 180
TWO HOT SWAP BAYS !
post #44 of 180
Case came with extension cable for 12v Power plugs
post #45 of 180
post #46 of 180
post #47 of 180
post #48 of 180
post #49 of 180
No need for a fan controller with this case.
post #50 of 180
post #51 of 180
coolermaster makes it easy
post #52 of 180
WoW, nice!
post #53 of 180
post #54 of 180
Originally Posted by baipai View Post
WoW, nice!
post #55 of 180
post #56 of 180
post #57 of 180
post #58 of 180
post #59 of 180
post #60 of 180
