AVS › AVS Forum › Video Components › Home Theater Computers › HTPC won't power off on shut down
post #1 of 3
post #2 of 3
Verify that the power and reset plugs are correctly in the right pin header. Those little plugs can be tough to get on the right pins, especially if you have large hands.
post #3 of 3
Thanks for the reply. I defaulted my BIOS setting and it fixed the issue. Thanks again.
