AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Help with a decision
post #1 of 5
HI All.
I recently purchased an Onkyo 3009. I have an older SVS PB10-NSD. I hear XT32 does a great job with dual subs. Would I be better off trying to find a sub to match the svs or go with a newer higher performance single sub? One of the subs I'm considering is the eD A3-250. I kind of shot my budget on the Onkyo so, the less money the better. My room is not that large and our listening is 95% movies and concert dvds.
Thanks for any input,
Zaxdad
post #2 of 5
I choose get a better sub and with the VTF-15H it gives me all I wanted and then some. Obviously you are looking so something is lacking on your current sub that one more may not cure.
post #3 of 5
Originally Posted by Zaxdad View Post
I have an older SVS PB10-NSD. ... Would I be better off trying to find a sub to match the svs or go with a newer higher performance single sub?
Unless you're really unhappy with the PB10-NSD - which, IMO, is a terrific sub (I used to own one) - I'd double up with a gently-used PB10-NSD.
Failing that, and depending on whether your budget permits it, a single HSU VTF-15H or Epik Empire might be worth looking into.
post #4 of 5
I'm not really unhappy with the SVS. My room is not that large so output is not an issue. It's more to take advantage of the xt32 capabilities. Also,I'm sure a used SVS is going to cost a whole lot less than a HSU or Epik.
post #5 of 5
Yup. Find a nice used one. It'll go a long ways toward smoothing out the response in your room.
