AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Matching power recliner..pls help
post #1 of 3
Hello,
I have a microfiber/suede tan loveseat that i want to use for the front row theater. The back row (riser yet to be built) will house a new loveseat or 2 seat home theater seat. I hunted around the seattle area but couldnt find something that matched this color and in leather. Can anyone recommend some online models? My requirements are:
1. 2 seats
2. Leather
3. Power Recliner
4. Under $1300 all said and done
5. Good lumbar and head support
6. Last but not the least, match the seat shown in the pic for WAF.
Thanks for any pointers...
post #2 of 3
You are likely going to need to do a custom leather to match the fabric on that love seat. In that case, given your budget, look at:
Lane
Palliser (if you are willing to increase your budget a little to pay for Power Recline)
If you are willing to consider Dark Brown Leather (which I think would look great in that room and fine with the love seat) then that opens up a world of possibilities of in stock chairs in your price range. All of the other requirements are no problem.
post #3 of 3
Thanks, Ken. Can you recommend some websites ?
