AVS › AVS Forum › Blu-ray & HD DVD › HDTV Software Media Discussion › When do you think they will launch a 4K optical (or other physical) consumer format?
post #1 of 18
When do you think they will launch a 4K or 3840x2160 optical disc (or other physical) consumer media format with pre-recorded content. eg. like Blu-ray 4K?
Or if you think the next physical consumer media format will be higher resolution than 4K, click the option in the poll when you think the format with that resolution will be released.
This is including a Blu-ray "4K" format that wouldn't be classed as a "new format". ie. would still be known as Blu-ray (ie. select when you think a version of Blu-ray which, in it's specs supports 4K or 3840x2160 or higher for pre-recorded content, and the first title will be released).
post #2 of 18
If the adoption rate in the US for HDTV and Blu-ray is used as an indicator then I would say it will be beyond 2020. HDTV over SD has been a hard sell, SHDTV will be that much harder.
post #3 of 18
Even while (home) video broadcast|cable|IPTV|satellite distribution remains effectively limited to 1080p, it seems to me that once the home player-AVR-display chain is capable of native 4K2K reproduction "at near current AV hardware prices" (which seems likely to happen no later than 2013|2014), there will be an incentive to shoot for TV (in 4K2K or better) with the intent to improve 'after broadcast' disk sales through the promise that "these (4K2K) disks can deliver better quality than the original 1080 over-the-air|cable first run of the show". As the manufacturing cost of 4K2K disks should be comparable to that of (current 1080) BD, and sales would probably be higher, this seems like a sure thing...?!
post #4 of 18
And if we try to guess what might be 'state of the art' home AV technology Post-2020...?!
From the NHK Annual Report 2010...
5.2.2 Optical storage technology
We are advancing with our research on thin optical disks and holographic recording technology for future program archives and Super Hi-Vision (SHV) recording equipment.
■Thin optical disks
Thin optical disks with thickness of 0.1 mm are promising candidates for program archives and
home SHV recording equipment because they can rotate at higher speeds, thereby giving them higher data transfer-rates. In FY2010, we developed a high-capacity drive system using thin optical disk drives. In parallel with this development, we proceeded with the development of near-field optical recording technology for increasing the recording density of thin optical disks.
Figure 1. Prototype compact thin optical disk drive
[So we might need to replace those optical media players 'just one more time'...?! ]
post #5 of 18
High Efficiency Video Coding
High Efficiency Video Coding (HEVC) also known as H.265 is a draft video compression standard, a successor to H.264/MPEG-4 AVC (Advanced Video Coding), currently under joint development by the ISO/IEC Moving Picture Experts Group (MPEG) and ITU-T Video Coding Experts Group (VCEG).
http://en.wikipedia.org/wiki/High_Ef...y_Video_Coding
post #6 of 18
They had an 8k television at CES. Why would I be happy with just 4k?
post #7 of 18
If you have 20/20 vision and watch native 8K4K (7680x4320) resolution source material on a 100" (or smaller) 8K4K resolution display from a distance of 6' (or further), it is visually indistinguishable from the same source material down-sampled and shown on a same-size 4K2K (3840x2160) resolution display. So only those homes with significantly larger than 100" displays would likely be adversely affected by limiting the native resolution of HOME ENTERTAINMENT disks and|or displays to 4K2K.
post #8 of 18
Or those who watch on 100" TVs at less than 6.54 feet, or 80" ones at less than 5.23 feet. Or those who have better than 20/20 vision. Or if the TVs with more pixels can produce a visually better/more accurate picture (in colour output too) than those with less, from whatever viewing distance. Or if the screen isn't flat or 2 dimensional.
post #9 of 18
Technology for the home is limited not only by pure science but by public demand: How much will they spend and how much do they care. "If a man...can make better chairs or knives, crucibles or church organs, than anybody else, you will find a broad hard-beaten road to his house." --Ralph Waldo Emerson. Build a better TV or projector, a better player, a better broadcast system, and price all of it so it's easily affordable to everyone, and it will sell.
Right now, though, even high definition is a hard sell for some people because it means shelling out too much money. HD will (has) become a default among TV's only because that's almost the only thing you can buy anymore except for the tiniest of home screens. 3-D fell on its face because people don't want to spend an arm and a leg for new equipment they don't perceive as worth it. So, simply launching a 4K system is one thing; selling it is another. Give the current technology another five-to-ten years, and we'll talk about it.
John
post #10 of 18
HDD Attends a Virtual Roundtable with Andy Parsons (BDA) and Lori MacPherson (Disney)
Q: Are there any plans to amend the Blu-ray spec for 4K content? If so, do you know how much 4K content can be included on a BD50 disc or whether additional layers will be required.
Andy Parsons: At present, there is no activity within the BDA to bring 4K into the specifications. However, it's clear that the interest level is high for its use in home theater applications, so we are keeping a close eye on the developments in the CE market. In the meantime, I think 4K displays will do an excellent job of making HD (2K) Blu-ray titles look even better via upconversion. When the time is right, let me say that Blu-ray will be the best way to bring 4K into the home, as the data density is much higher than HDTV, and it's doubtful that even a good broadband connection can provide enough bandwidth to reliably reproduce a good picture.
http://bluray.highdefdigest.com/news/list/4
post #11 of 18
"...it's clear that the interest level is high for its use in home theater applications, so we are keeping a close eye on the developments in the CE market. In the meantime, I think 4K displays will do an excellent job of making HD (2K) Blu-ray titles look even better via upconversion."
Yes, interest is high among manufacturers, who fear that most consumers have already bought an HD television and need to find something new to sell them. Interest among consumers? Probably nil at the moment. It's still all about public demand; the public have to want it and be willing to pay for it. Right now, that will be a hard sell. As I say, give it a few years; the economy picks up, people are tired of ordinary HD, they want something new. The manufacturers have it ready.
John
post #12 of 18
I have to agree. Interest among consumers is practically nonexistant at the moment. The average consumer with a 40" HDTV is unlikely to find their current setup in any way lacking.
post #13 of 18
Extract from "Dr Hiroshi Shimamoto, NHK, discusses Super Hi-Vision prior to ImageSensors2012"...
Q: Your presentation will cover image sensor specifications for the new Super Hi-Vision - can you tell us more about the Super Hi-Vision project / programme?
A: Super Hi-Vision (SHV) is a future broadcast system that will give viewers a great sensation of reality. SHV consists of an extremely high-resolution (16 times of HDTV) imagery system and 22.2 channel super surround multi-channel sound system. We are now proposing to extend its frame frequency from 60 Hz to 120 Hz to improve the motion picture quality, and to have a wide-gamut colorimetry for better color reproduction. We call this new SHV system "full-spec SHV".
Just when you thought it was ok to stop adding more 'safety capacity' to the estimate of your home theater's planned bandwidth for the 2020's!
post #14 of 18
Yes, interest is high among manufacturers, who fear that most consumers have already bought an HD television and need to find something new to sell them. Interest among consumers? Probably nil at the moment. It's still all about public demand; the public have to want it and be willing to pay for it. Right now, that will be a hard sell. As I say, give it a few years; the economy picks up, people are tired of ordinary HD, they want something new. manufacturers have it ready. John.
But Harrods (London) apparently thinks there is already a small (but wealthy!) market for 4K2K displays: "The 152-inch Panasonic TH-152UX1W is the world's largest commercially available flat-screenis typically used in airports and theme parks" but it's also (supposedly) available "at retail" from Harrods for $958,000 (£600,000).
With a recommended 2D viewing distance of around 9', this seems like the ideal end-of-the-bed accessory!
Edited by SoundChex - 6/6/12 at 10:09am
post #15 of 18
we've all seen this chart before..
http://s3.carltonbale.com/resolution_chart.html
Sitting 10 feet from an 80 inch screen you might notice a difference.... assuming it's a live broadcast or show filmed with a digital camera that lacks grain. Don't get me wrong, I'd love to see it, but I'd love to see 1080p done without compression artifacts first, before starting to worry about 4k..... to see them actually ditch the analog cable channels and digital in SD and actually fully embrace HD and leave the old grannies in the dust.... the list goes on... It will cost a lot of money to upgrade tv stations for another, even more high resolution format... I just don't see the demand for a very long time... with the exception of multimillionaires who live in another reality from the average joe anyways....
2020 at the earliest. Since the world ends this year, no need to worry about 4k.
post #16 of 18
Lmfao...yeah, a proverbial "laundry list" of conditions that do not exist within 99.99% of the populace and/or viewing scenarios.
Good one.
James
post #17 of 18
Right now, though, even high definition is a hard sell for some people because it means shelling out too much money. HD will (has) become a default among TV's only because that's almost the only thing you can buy anymore except for the tiniest of home screens. 3-D fell on its face because people don't want to spend an arm and a leg for new equipment they don't perceive as worth it. So, simply launching a 4K system is one thing; selling it is another. Give the current technology another five-to-ten years, and we'll talk about it. John
Consequent to the somewhat hyped already current perception of added value to high density displays on handhelds, plus some likely real benefits to medical|industrial tasks, I suspect your time frame may be overly conservative (viz):
In "Intel: super-dense notebook, desktop displays common by 2013" (link), an electronista.com article (updated April 12, 2012) reporting on Intel's Developer Forum in Beijing, we see:
"These would include 11-inch ultrabooks at 2560x1440 through to 21-inch desktops with 3840x2160 screens. Intel also expected "halo" 15-inch notebooks with the same 3840x2160 output, which would create a Retina Display-like effect."
If we really do get 21" to 32" PC monitors with 3840x2160 resolution at mass market prices 'starting by 2013', then 21" to 60" TVs with the same resolution (and perhaps some cheaper 2560x1440 resolution models) would probably be the "everyman" price point staple for Big Box stores only a year or two later . . . likely resulting in an 'effectively complete' evolution of the US home TV installed base to the 3840x2160 resolution standard by about 2025--and uncoupled from the actual progress towards 4K2K broadcast OTA|cable, IP streaming, or BD4K adoption.
So it seems possible that, while there remains uncertainty as to when 4K2K source material might be 'widely available', there will likely be a substantial base of 4K2K displays already in-place if-and-when 4K2K source material finally does become common.
post #18 of 18
Good one.
James
Have a look at the thread title. Obviously not many people are viewing on 4K (or 8K) displays yet. There's not much content to view on one yet either even if they did buy one. And yes, my post was also about displays that could be something other than a normal (flat, 2D display). ie. a future display.
Obviously 99.99% of the population are not viewing displays at appropriate viewing distances for 4K/8K, since they don't have 4K/8K etc. displays yet. The "viewing scenario" won't really change until the display they buy (eg. 4k etc.)/media format/content means they change it.
  Back to Forum: HDTV Software Media Discussion
