I'm a new owner of i1Display Pro unit and I can say this to answer your questions:
- I have successfully calibrated my HDTV using i1Display Pro + HCFR 3.0.4.0 and the results are the best I've ever had (far better than my old Spyder2);
- X-Rite i1Profiler has a REC.709 preset but i1Profiler relies on ICC profiles that you can't use in your TV. HCFR id better suited for TV with it's gray scale measurement etc;
- In HTPC, if you use i1Profiler, then you don't need those video files. I calibrated my HDTV with i1Display Pro + HCFR v3.0.4.0 + AVS HD 709 - Blu-ray & MP4 Calibration files fond here: http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
To sum it up, I'm very glad I purchased i1Display Pro and was able to calibrate my HDTV better than ever before.
