I previously used the Color HCFR software with my i1 Display LT to calibrate my plasma TV and various LCDs. I'm about to purchase my first projector in the very near future and will probably be looking to get a new colorimeter.
I was thinking of either the ColorMunki Display or the new i1 Display Pro. I'm guessing that the meters are the same, much like the old i1 Display 2 and the i1 Display LT were the same meters, and the only difference between them was the software. That likely being the case, (correct me if I'm wrong) and my being intimately familiar with HCFR, I was leaning towards getting the ColorMunki, if, and that's a big if, HCFR can actually be used with the ColorMunki Dispaly, or the new i1 Display Pro for that matter.
My question is, is there a list of new meters that works with HCFR, and is the ColorMunki or i1 Display Pro one of those that does?
If not, what meter would you recommend to use with HCFR for profiling a projector?
Lastly, has anyone used the software included with the ColorMunki Display or i1 Display Pro, and if so, is it a viable option for serious profiling or is it too basic to be even adequate?
Edit:
Clicked on the link to download the newest version of HCFR and saw notes there on a few meters. Seems that it does support the ColorMunki Display, correct? Save for a few issues that appear to have been resolved. Please let me know if I am correct on this.
I didn't see the i1 Display Pro listed. Should I take it to mean that it is not supported, or is that just a list of meters that have some issues so they are noted and not the full list of compatibility?
Edited by Stuntman_Mike - 1/7/13 at 8:04am
