The current version, which is the only one you should be using, uses CIELUV without the consideration of luminance for grayscale. This is identical to the original version 2.1 selection "do not use luminance in deltaE formula" selection. I've compared the two versions to verify they are the same.
For color you have the choice of CIELUV (with luminance consideration) or CIE94.
Here is a comparison of dE values between Calman dEuv calculation and HCFR
Edited by zoyd - 2/10/13 at 4:38pm
