Originally Posted by 65Cobra427SC
Not sure what you mean by jumped around like crazy. Could you explain what you're doing at that point? For example, when I measured Grey Scale I didn't see any values until I finished going through the 10 screens. The program requested each screen one at a time, and each time I was ready I clicked on the OK button and it would ask for the next screen. So the only time I saw measured values was after the measurements were done.
Sure thing. When you click on the green arrow, it takes free measures, meaning it updates in realtime as the sensor takes new readings. At high IRE values (100-60) if you look at the x,y, and Y you'll see them moving a bit, but the RGB bars are more or less stable. Once you get to 50 IRE test patterns, the bars start jumping around, making it very difficult to determine what the true reading is. I had to do some mental averaging as well as using a bit of guesswork based on sight and previous experience.
