Originally Posted by DaGamePimp
1) Yes this is the same regardless of software, this is how most of the colorimeters do their calibration. Don't use a shiny reflective black surface, just a matte black.
2) I believe the VW85 should be non-refresh with lamp based front projection spectral. CRT and Plasma use refresh.
3) You'll use the i1d3ccss.exe in the tools directory to 'unlock' those spectral pre-set tables for greater accuracy (per display type).
Jason
Jason
Thank you so much Jason!
