Hi,
very nice work indeed, I have installed the driver for the colormunki and it works without problem.
I have only one question, I don't use a colormunki "photo", but a colormunki "design" :
http://www.colormunki.com/product/sh...gner_type=true
Normally, it's the same meter and only the software sold by X-rite is different between those meters .
I have a problem with an option in "paramétres du Argyll Meter" on this point :
"Use Hi-Res Mode (i1pro and colormunki photo only)"
In your opinion, can I select that option with the colormunki Design ? (because normally it's the same as colormunki Photo).
That is interesting, coincidence? I posted a measurement
. I think we purchased the i1Pro around the same time. The used one I purchased reads higher, and I think it's newer - seems like the i1P2 reads lower in your case. In any case, it doesn't make much difference when calibrating.
