AVS › AVS Forum › Display Devices › Display Calibration › HCFR - Open source projector and display calibration software
post #1 of 3446
Hi and welcome to the open source HCFR software thread.
This thread was originally started by JohnAd who had the nice idea of creating an open source fork of the original HCFR Colormeter software to integrate the existing GUI and all of it's calibration features, with the meter handling code of ArgyllCMS. Since ArgyllCMS is continually adding and improving meter support, HCFR benefits by staying current with these developments.
The software is frequently referred to as HCFR or colorHCFR where HCFR is short for "Home Cinema-FR", a French forum where some of it's members originally developed the code to support their home-brew colorimeter in 2005.
Along with the meter handling improvements introduced by ArgyllCMS, I have been working on improving and adding features to the color engine and internal pattern generator.
Please use this thread for bug reports, usage questions and suggestions for improvement. Anyone wishing to help with code development should join the developers mailing list.
The latest version of HCFR (3.1.0.7) can be found here.
Changelog
Help Wanted (pm zoyd)
  • Language translation
  • Update French and German with recent changes
  • Full Spanish, Italian, others? needed
  • Help file updates
  • PDF Quick Guide
User wl1 has provided some useful links for beginners to display calibration as well as links to helpful posts within the thread. Please take a look before posting to see if your question has already been answered. There is also a FAQ section below that may be helpful.
Useful Links
- Display Calibration - Part I
- Curtpalme - Calibration Guide for Dummies
- Basic Guide to Color Calibration using a CMS (updated and enhanced)
ArgyllCMS Probe installation notes
- Spears and Munsil
- Choosing a Color Space | Spears & Munsil
- The Secrets Blu-ray Player HDMI Benchmark Part 1  and Part 2
- Original version 2 avsforum discussion thread
- Another version 2 discussion thread
Links to Tools & Utilities
- AVSHD709 Test Disk
- GCD Disk
- Mascior's Calbration Disc
- dispcalGUI (front-end to ArgyllCMS)
Thread Summary (from Post 792, New Scientist)
Post No. Comment
#151 to #155 - installing i1Display Pro
#159 - use of i1Display 3 3/1/2012 (march 1st)
#161 - removal of non-free code (for accessing meter)
#162 - x-rite driver (.dll) use
#165 - spotread
#167 - spotread
#174 - problems with i3D3
#180 - observations re use of i1D3
#183 - reply to #180
#189,#196 - x-rite drivers
#198 - x-rite drivers
#202 - installation i3D3
#226 - a first attempt at calibration
#227,#236 - i1D3 not requiring calibration
#231 - ccss
#248,#253 - i1D3 not requring drivers from x-rite to work with HCFR
#257,#258 - i3D3 with HCFR
#263 to #270 - analysis of #258
#275 - spreadsheet for setting gamma
#277 - spreadsheet uses
#325 - HCFR v3.0.1.0
#397 - using i1D3
#416 - graphs from testing i1D3
#425 - EDR and i1D3ccss tool
#426 - v3.0.2.0 issues re i1D3
#428 - generate .ccss files from i3D3 disk
#442 - v3.0.3.0
#487 - v3.0.4.0
#507 - what is .ccss
#509 - refresh and i1D3ccss.exe
#514 - what is .ccss and .EDR
#519 - i1D3ccss usage
#528 - where should the .ccss files go?
#534 - ARGYLL_COLMTER_CAL_SPEC_SET environment variable
#540 - some addtional ccss file info (plasma displays)
#552 - ccmx file
#600 - i1D3 not showing in Sensor list
#610 - "Use measured colors", in Preferences -> General, option
#678 - i1D3 and i1 Display Pro differences
#682 - comment re issue with v3.0.4.0 and i1D3
#688 - which driver to use
#717 - i1D3ccss tool
#732 - do I need drivers or not?
#786 - spectral sample files
#824 – Steps to load Driver
# – i1D3 reds on Plasma - matrix
#876 – ColorMunki Display guide
#898 - 904 – Pana Window sizes
#1008 – Comparison of HCFR 2.1 and 3.0.4.0
#1083 – HTPC Cal. Suggestion
#1105 – Updating and removing Argyll Drivers
#1114 – Plasma Essential Reading
#1122 –i1D3Pro  - initial accuracy study/background to meter matrices
#1146 – Matric Correction file info
#1150 – Import Matrix file into HCFR
# 1205 – 2 point V 10 point Calibration
#1215 – Warming up meter
#1241 – profiling Meters
#1250 – Matrix file for Display LT2
#1258 – errors in HCFR ? Red push?
#1260 – GT30/VT30 Experiences
#1270 – WARNING – HCFR Matric different to CP or CM
#1280 – Zoyd Steps in -  Installation package and baseline Integration value
#1285 and 1299 – The fixes explained – instability @30%IRE
#1303 – Argyll Driver suggestions
#1336 –build from Zoyd – USB fixes
#1337 – Plasma/LCD – definitive Refresh settings and Calibration of meter (>50%)
#1344 – Lots of changes to HCFR
#1352 – List of more changes – BT1886 gamma target
#1354 – More info link on BT1886
#1357 & 1360 & 1370 – Answers about changes – and gamma recommendations
#1380, 1390 – another build
#1398 – Fork of a Fork
#1411 – Luminance and Delta E – Yes or No?  Colour or Grey?
#1420 & 1426 – 3.0.4.1 Changes
#1424 – Use of GCD Disk Colour Checker Pattern
#1512 & 1515 & 1558– Version 3.0.4.2 Changes
#1521 – Run HCFR with Admin Privilleges
#1523 – Projector questions and suggestions
#1537 – Explanation of Change to HCFR calculation of gamma
#1647 – LCD and LD ON/OFF?  Plasma and ABL – guidleines
#1648 – Preferences -> General -> gray levels rounding assumption to unchecked? AVCHD,DVD=checked, GCD,internal patterns=unchecked
#1650 – Can I use matrix from D3 for LT2?  No – see  1651
#1663 – BT.1886 or not?  Depends on if you have 10 point control
#1702 – BT1888 is not meant to be flat
#1722 – Samsung D & E -75%A and 75%S recommended
#1774 – Explanation of affect of Patterns to gamma and light output results
FAQ:-
To follow.
Edited by zoyd - 3/27/14 at 9:56am
post #2 of 3446
Any developers with a good knowledge of C++ and MFC who wish to help out, add features or test particular meters should join the development mailing list
https://lists.sourceforge.net/lists/...hcfr-developer
Look forward to hearing from you.
John
post #3 of 3446
Cool. Good luck. I'm loving HCFR so much more now that I own a i1pro and Display2.
Support for display3 should be a priority.
Something easy could be more graph options and maybe report generation.
Long live the legend, HCFR!
post #4 of 3446
It's not bad for freeware but cost aside I much prefer CalMAN or ChromaPure.
post #5 of 3446
To each his own I guess. HCFR is a lot free-er.
( I don't think I'll ever choose CalMan but I would be happy to use Chromapure eventually. )
Back to suggestions: it's easy to profile my dispay2 to my i1 pro in HCFR, but it could be even easier if the process was better integrated.
post #6 of 3446
I can test with ver 5.1 of the HCFR TAOS based probes as I have several. I subscribed to the dev forum. I can hack in VB and have 2008 visual studio that I would be interested in having a build environment working.
It's great to see this arising again.
post #7 of 3446
My main gripe is that it needs updating and support for newer hardware. I do like however that it supports the i1pro spectro.
post #8 of 3446
The killer notion would be: a Mac version!
CalMan and Chromapure are ignoring Apple.
I would help making an iPad version. (I'm not sure how but I would help anyway I could.)
-Brian
post #9 of 3446
Agreed that and the colormunki are the 2 main popular meters missing
Not sure about easy ...
At least initially I'll be focusing on opening the use meters up so the taking and sharing of readings is as easy as possible, this probably means dumping data out to spreadsheets for graphing/reports rather than building too many more screen in hcfr as at the moment each graph seems to be quite a lot of code.
John
post #10 of 3446
There was a mac version, I just haven't got the code for that, I'm happy to try and restart that though if anybody has the source let me know.
John
post #11 of 3446
Cool, should be just a question of installing git (I Use tortoisegit) and pulling the source from sourceforge and then building the project.
post #12 of 3446
Meters supported will be the same as
http://www.argyllcms.com/doc/ArgyllDoc.html
John
post #13 of 3446
John
That's awesome!
I have the Mac version (not the source code though) but I think it supports even fewer meters. Like just the spyders
post #14 of 3446
I read the above comments, and my main gripe with HCFR is that the red, green, and blue data on the luminance and gamma graphs is normalized. I think the non-normalized data when you choose the display RGB checkbox is a lot simpler to understand, but unfortunately new users typically find it easier to have graphs to represent the data. I consider it more intuitive to have one graph that represents the entire grayscale run, rather than trying to get new users to understand what two graphs represent (luminance and RGB levels). Maybe it's just me, but I think comparing non-normalized red, green, and blue plots to a target gamma curve is far simpler to comprehend the limitations of 2-point grayscale controls.
post #15 of 3446
Ah this is excellent to see. I'd be very keen on a mac port, and likely to contribute to it, so hopefully the source can be found...!
post #16 of 3446
Continuous real-time 11 point gamma display.
post #17 of 3446
From what I remember, HCFR doesn't calculate dE's of colours correctly. You'd also have to manually calculate what the luminance level should be for each colour then adjust brightness to that.
post #18 of 3446
Thanks for all the feedback so far, so quite a lot to do then
I've only really used it at a way of getting raw measurements so haven't really seen a lot of the issues metioned.
Correcting the dE and normalising side of things should be fairly straightforward, but I'd expect getting agreement on what's right to take longer....
John
post #19 of 3446
I think HCFR excludes Y errors from dE, is that what you mean or is there a bigger issue?
Not sure what you mean here, is this for non-additive displays?
John
post #20 of 3446
I don't know if that's possible. Wouldn't you need 11 measuring devices?
post #21 of 3446
I don't think HCFR leaves Y out of color DE. Currently I have green with perfect xy and 30% Y error and de is high.
I'm not even convinced HCFR calculates color de wrong. This is something I could investigate. It's easy enough to manually put in the data thats correct and then modify it different ways.
post #22 of 3446
Can you give a bit more of a description of what you mean, how you would see this working? Do you mean you pick which point you are doing and then working with continuous readings and a target?
Would you expect to normalize the luminance of the 100% or the 109% point?
So do 0% to get black, 109% to get peak and then do 100%, 90%... 10%
John
post #23 of 3446
Sure would be nice to be able to put up 75%, 50% and 25% saturation points on the gamut chart since many use 75%.
This way using Continuous Measure to align hue and saturation would be simplified.
post #24 of 3446
Looking through the code there seems to be some quite confusing labeling going on.
In the advanced tab, there are 2 settings at the bottom
The first of those "Do not use luminance in delta E formula (V1.x)" corresponds to the internal setting Use Old DeltaE so should be off.
The second of those is "Use gamma reference to compute gray scale delta E" should be on if you want Y to be included in dE and off if you don't.
The default for both is off so unless you change something Y is not included in dE.
post #25 of 3446
John
I think what he means is actually a 9-point gamma real-time tracking for 10% - 90% (0% black and 100% white have no gamma value). Right now it is not convenient to do that because the target Y values are calculated only after a complete grayscale run from 0% to 100%. If I'm only adjusting the gamma of, say the 70% point, what I need to measure is the 0% Y value and the 100% Y value, and the target Y for my 70% point should be calculated and show up on the screen for me to shoot for that value (using continuous measure).
post #26 of 3446
Yeah,... I use a secondary excel spreadsheet that I put in the 100% Y value and it gives me the rest for any gamma target. This way I can adjust other values without running the whole set of measurements.
There's no lack of things do suggest for HCFR since it's not been updated in years. Just enhancing the meter support would be HUGE.
-Brian
post #27 of 3446
[/QUOTE=Brian Hampton;21643233]Yeah,... I use a secondary excel spreadsheet that I put in the 100% Y value and it gives me the rest for any gamma target. This way I can adjust other values without running the whole set of measurements.
-Brian[/quote]
Same here - having to use a separate spreadsheet is a pain with HCFR, would be great to be able to use the HCFR 100%Y value and have the program calculate at least the 100% & 75% saturation levels for a gamma target, should not be too hard to do. Link to spreadsheet that shows how this is done: http://www.avsforum.com/avs-vb/showt...7#post15607437
Also support for the new Display-3 would be great. Just adding these two features would make HCFR useful for most of the basic DIY calibration tasks.
post #28 of 3446
John
I want it to be able to take the 100% Y reading and calculate the appropriate Y reading for each level down to 10% (90%, 80%, 70%, etc) so that I can adjust the level of Y at each level to match the calculated target to achieve the gamma I want at each level.
...and I want to be able to make these adjustments in real time without having to refer to a spreadsheet..
As it stands now, all you can do is do a full set of grayscale measures and see what the (average) gamma is and see the curve displayed on a chart. You can't see the results of any gamma corrections you make in real time. You can just guess at some corrections and then do another full set of grayscale measures, and keep repeating until you get a gamma reading you want.
post #29 of 3446
Yes, that is what I meant.
post #30 of 3446
This may not be necessary. You can display the %stimulus pattern in question, e.g. a 70% window, use free measurement to observe the measured xyY value while changing your gamma setting for 70% in the TV/projector, and align the measured Y to the target gamma Y as shown in the measurement table.
If you suspect the 100% luminance level is changed, you can check the box "Editable data" in the measurement table, do a free measurement at the 100% pattern, copy-and-paste the measured xyY data (on the left side of the screen) to the column of 100% data, and all the target gamma Y values for 10% - 90% will be refreshed.
Of course, this will work only if you have done a complete grayscale run; and the process is too clumbersome.
