AVS › AVS Forum › Display Devices › Display Calibration › HCFR - Open source projector and display calibration software
HCFR - Open source projector and display calibration software - Page 36
post #1051 of 3446
Originally Posted by PeterLewis View Post
How do you post snap shots from th HCFR screen to a site?
If you want a screenshot of the entire HCFR window, highlight the window by clicking on it, press and hold the "ALT" key, and press the "Print Screen" key. Release both keys. Open a graphics program (I use Irfan View) and paste. Save as a file. When posting on the board click on the image icon, and browse for the file you just saved.
post #1052 of 3446
I wanted to thank JohnAd again for his hard work on colorhcfr... used version 2 for a long time and really appreciate being able to use on my new xrite meter...been using it to and rechecking my projector
post #1053 of 3446
@vega509
Thanks for the tip regarding screen shots..
Also Vega,If i calibrate my plasma using small apl to do greyscale,do I use the small 75% color apl to calibrate color as well or do you use standard windows for color calibration?
post #1054 of 3446
@vega509
on a plasma I use the small APL for both to avoid the limiting circuits throwing the calibration off. LCD and LED I use full fields.
post #1055 of 3446
Ok thanks..
Edited by PeterLewis - 10/30/12 at 11:18am
post #1056 of 3446
I have CalMAN 5 Enthusiast on my newer laptop but wanted to try this updated 'fork' of HCFR on my older one that doesn't work with CalMAN 5. What changes/additions/improvements does this version of HCFR have over the original one made many years ago?
post #1057 of 3446
3.0.4.0 has support for the i1display3, it uses argyle drivers for may other meters (see 1st post). The workflow is the same. There are probably other changes, but none I can see with the way I use it.
post #1058 of 3446
Are there any differences in calibration between a WHITE screen and a GRAY screen?
Does Rec 709 calibration apply to both white and gray surfaces?
post #1059 of 3446
white is pure white, black is pure black, gray are the shades in between black and white,
post #1060 of 3446
...and?
post #1061 of 3446
...and?
White is gray at a different luminance, and vise-versa. Even "black" is white at a different luminance(and vise-versa) in the calibration world. No difference.
post #1062 of 3446
Will the i1display pro that i can get from ebay work with HCFR? What would be the best meter to get for around $250?
post #1063 of 3446
Where do you get the argyle divers? And where is the old "Post your HCFR results Here" forum?
bob
post #1064 of 3446
Yes.
The i1Display Pro/i1D3 is the best meter under $300.
bob
They're integrated into HCFR. You just need to plug your meter in to let windows recognize/install it, then it should show up as an option in HCFR.
post #1065 of 3446
How different are ColorMunki Display and i1Display Pro/i1D3, in terms of calibrating plasmas or projectors using HCFR? It seems they have almost identical hardware, with the major advantage of i1Display Pro/i1D3 being 5x faster. If there are little differences between them in capacities and accuracy, I will have no problem to scarify some speed to save about 80 bucks.
post #1066 of 3446
post #1067 of 3446
Originally Posted by rahzel View Post
Yes.
Still can't get my DPT-94 meter to work right. Now it says "Incorrect driver- Starting communications with the meter failed with severe error. Argyll Error" The meter will still measure when I push the green arrow but when I try to do a gray scale run, I get "Error during initialisation"
Any ideas?
thx
bob
post #1068 of 3446
Any ideas?
thx
bob
not sure about the DPT-94, but if you are using 3.0.4.0 it should show in windows device manager as Argyle xxxxx ........ If it shows as anything else, double click it, chose update driver, search fro driver, and go to the HCFR drivers folder.
post #1069 of 3446
It does show up there now, not under the usb tree. I thought I had it when I realized I had to update drivers to the included drivers folder but still no go; at least not 100%.
bob
post #1070 of 3446
Does your meter work with HCFR 2.2?
post #1071 of 3446
It did but now that I tried to upgrade and even went back to version 2, I get the errors? Prolly a driver conflict now that I tried so many and put them everywhere, sys 32 folder, etc.
thx
bob
post #1072 of 3446
Hello friends,
i have a i1 D3 meter, and i want apply corrections at measures.
I have the xyY values diff. Can i apply this diffs to my measures on HCFR 3.0.4?
Eg., i want apply +0.002 in x on white measures, i want apply +0.003 in y on red measures, etc...
Is possible?
How can i do this?
post #1073 of 3446
Are you sure that HCFR measures properly with Spyder4?
Because I have had great difficulty in obtaining a satisfactory result with HCFR (Huge surplus of green) I tried to calibrate using datacolor own software, then I open my ICC profile using ICC Profile Inspector and get the following result
Code:
Red: x, 0.640023, y, 0.338314
Green: x, 0.328698, y, 0.641197
Blue: x, 0.155382, y, 0.058208
with HCFR
Code:
Red: x, 0.625469, y, 0.333092
Green: x, 0.308994, y, 0.647111
Blue: x, 0.150739, y, 0.052200
Calibrate I through hcfr I get a considerable under-saturated image. This is particularly evident on blue. It is also blue I adjust very massive to achieve a correct grayscale ... sooo
Edited by MSL_DK - 11/15/12 at 4:47am
post #1074 of 3446
Question about calibration files
I am reading my front projector display (with a UHP bulb) off the screen with an i1 Display Pro meter. Can someone explain which calibration file(s) I can use to improve the accuracy of the readings. In this thread there is talk about colorimeter calibration spectral sample files, i1d3ccss.exe, EDR files and so forth, but I really have no idea what I'm supposed to do with all this to take advantage of this feature to get improved accuracy. Has anyone figured this out yet? What EDR file would I feed to the i1d3ccss in my case, and then where would I put the output file (supposedly that it would generate?) so that HCFR sees and uses it?
On another note - the bug where the secondaries Rec 709 targets do not plot on the gamut chart under Windows 7 x64 has apparently not been fixed. Does anyone know if the developer is aware of this?
post #1075 of 3446
The EDR files come with the iProfile software that ships with the retail version of the i1Display Pro. X-Rite calls these "technology types". If you installed the iProfile software in the standard location, then these EDR files should be located at C:\Program Files\X-Rite\Devices\i1d3\Calibrations. My installation has five types: CCFL, Projector, RBG LED, WG CFL, WG LED. These files can then be converted to ccss files for use by HCFR using the i1d3ccss utility.
Of course for your projector you would use the projector files. I want to see exactly how much these files change the colorimeter readings. maybe this weekend I will run a series of tests.
post #1076 of 3446
Sounds great. I will play around with it some more too and let you know how it goes. A few follow up questions please:
- When I selected the i1 Display Pro meter there was an option to pick between "Contact" and "Projector". I assumed that Contact meant that the meter was physically contacting the screen, and Projector meant you had it pointed at a screen. Are these assumptions correct?
- Underneath the Contact/Projector option there is an option for calibration files or something like that. Am I right to assume that is where I will find the ccss generated by i1d3ccss? Do I have to place the ccss file in a particular place for it to show up there (and if so, where?)?
- I guess there is not a profile for using the i1 Display Pro with the diffuser in place and reading out of the lens, but I could just make my own by profiling the meter to itself?
- I also have a Plasma set. Which display type should I choose for that - CCFL?
- The meter reading is unbelievably fast for this meter. So much so that I wouldn't mind slowing it down a bit just to see if I get more accuracy out of it that way. Is there a place to put in the meter reading time? I couldn't find it if so.
post #1077 of 3446
Hi!
I’m really (REALLY) new at calibrating using meters/software.
I recently bought a Spyder 4 TV HD to venture into this world. I’ve installed HCFR and followed the “Guide for Dummies”.
I got it pretty much figured out, but there’s one step I’m just not getting and that’s calibrating the meter before doing all the readings. In all the guides it says to put the meter in a black DVD case for calibrating, but in the newest version it’s says “ White Patch”?
To my understanding, this can mean three things:
- Putting the meter in a white dvd case and press “ calibrate “
- Project a white patch on the tv with the meter on the tv and press “ calibrate “ .
o In this case…if you do this before calibrating, how do you know the white patch is really white?
I hope someone can help me with a step by step “ Pre- “ guide. The Spyder 4 installs fine using the Argyll drivers, so no problems there.
And what is the general consensus for plasma tv’s: Refresh or Non-Refresh Display?
Thank you so much.
Erwin
post #1078 of 3446
Originally Posted by E-Nygma View Post
Hi!
Thank you so much.
Erwin
- "Non-Refresh display" => LCD
- "Refresh display" => CRT and Plasma
post #1079 of 3446
Thanks man! Been searching...and searching...
I did a calibration with non-refresh..Will do it again.
Love the program! Fairly easy to understand and use.
Though the Spyder is not some High End device, it will suffice for now.
Thx again, you've been a great help.
With Regards,
Erwin
post #1080 of 3446
Hi,
I have a quick question and hope someone can help me.
I previously borrowed a i1 Display Pro, and now wish to buy one. I will be buying a retail edition that comes packaged with xrite software...
However, from what I have read, the xrite software will not calibrate HDTVs, I'll need to buy calman.. Now, I'd buy calman, but it's too expensive for me, so I was wondering..
1 - If I buy an i1 Display Pro, will this software allow to calibrate to reference level?
2 - will the xrite software allow HDTV led calibration.
3 - can I calibrate my monitor (via my HTPC player) using the i1 display pro and the mp4 files on avsforum calibration disc and using the xrite or hcfr software?
I do hope you can help
Regards
