AVS › AVS Forum › Display Devices › Display Calibration › HCFR - Open source projector and display calibration software
HCFR - Open source projector and display calibration software - Page 5
post #121 of 3446
Originally Posted by 703 View Post
Since you're using argyll libraries, are you going to use the High Res mode for the i1Pro? As the i1Pro is not that great at low IRE's, even with the current crop of commercial software.
Can do, yes. Do you need a switch or should I always enable it?
John
post #122 of 3446
Originally Posted by JohnAd View Post
So my ouline plan is
Meter support
Clean up, correct, extend and test colour maths library
Go through ui and simplify code and ensure each point's target is correct and that the displayed calculations make sense.
So essentially getting what's there working better before adding major new features in the UI. There will be plenty of releases along the way and this whole process will take a while but should be worth it...
Should still be on for a first release with the new meter code this week.
John
Makes sense John, concentrate on the basics first. I'll be able to test next weekend for your first release if its ready.
post #123 of 3446
John
I'd recommend a switch but how it operates will depend on how the 3.33 nm vs. 10 nm sampling is handled. If the 10 nm mode averages 3 x 3.33 nm samples (rather than just picking out every third sample) this would be the preferred mode for low IRE color measurements. If the 10 nm sampling mode just picks every third sample then I would get rid of it and create the two modes in software using only the driver's 3.33 nm sampling and then do the calculations with either 1 or 3 sample averaging.
I think in general the high resolution setting will be used most often, especially if you are profiling a secondary colorimeter. In cases where you do not have a colorimeter or the display spectral display is smoother (non-plasma) the low resolution mode would be preferable.
post #124 of 3446
John
wow....that's great.
so should i pull the trigger on a colormunki display or an i1 display 3?
post #125 of 3446
I tried compiling the mac code on my 10.7 macbook pro and there were quite a few deprecated functions without obvious work-arounds. I'm not a programmer but bringing this code up-to-date appears to be a big job.
post #126 of 3446
It currently compiles cleanly in xcode 3.2, but yes upgrading it will be a lot of work.
John
post #127 of 3446
What flavor of of the Display 3 will be supported by the next release of HCFR? I'm ready to purchase it, and I'd love to sign up as an alpha/beta tester.
post #128 of 3446
Okay, it looks like I was mixing up information I saw on the CalMan and ChromaPure websites. If you're not buying a vendor customized one, it looks like there's one option:
Xrite EODIS3 i1Display Pro
Can you please verify that this will be the supported version? Also, will you verify that I can get on the tester list?
post #129 of 3446
i would definitely love to test this if it has support for ColorMunki Display....
post #130 of 3446
John
A switch for accessing both resolution modes for the i1 Pro would be very desirable -- and very much appreciated
Larry
post #131 of 3446
John
As a switch/check box would be great. So we can see for ourselves what difference it makes.
Would an application restart or meter re-init required for this?
post #132 of 3446
Supporting XCode 4 is a problematic, as there is no supported way of building for 10.5 in XCode 4. So, for the best compatibility, we are currently sticking with XCode 3, which allows us to build for and support 10.5, 10.6 and 10.7, at least for 32 bit builds. So XCode 4 doesn't buy us anything very worthwhile right now.
Building for 64 bit is going to be a fair bit of work due to deprecated interfaces, but is something I will attempt once we have the argyll driver working better.
post #133 of 3446
I haven't got a Display 3 and so I can only go on the code and the ArgyllCms website.
see http://www.argyllcms.com/doc/instruments.html#i1d3
The supported meters should be:
i1 Display Pro
ColorMunki Display
The CalMan edition of the meter
Exactly how what drivers need to be installed and what needs to be stopped will need to be worked out once we have a releasable verison of the code.
John
post #134 of 3446
Just keep following this post, I'll post links here as soon as there is anything ready.
I wired everything up for the first time yesterday and it's working pretty well. There are a few error handling and logging issues to resolve but that shouldn't take too long and then getting the driver package build properly ....
John
post #135 of 3446
OK, I'll look at adding it, A meter re-init only should be required.
John
post #136 of 3446
I have this exact meter, and can confirm it works in with Argyll and hence will be supported.
post #137 of 3446
Good plan, thanks for the info on the mac version.
post #138 of 3446
i1 Display Pro
ColorMunki Display
For sake of clarity, the CalMan edition of the meter means the i1Display3 OEM edition not the C6. According to the argyllcms list the C6 is apparently not supported at the moment.
John
post #139 of 3446
For sake of clarity, the CalMan edition of the meter means the i1Display3 OEM edition not the C6. According to the argyllcms list the C6 is apparently not supported at the moment although it may be in the future if Graeme Gill can get access to one.
John
I bought my OEM version from Tom with Chromapure and it works perfectly with argyll. So I propose dropping the reference to Calman and just say 'OEM' to cover both.
I'm very happy to see this project underway. I recently sent off my old LT to a friend and had a nightmare of a time creating offsets between Chromapure and HCFR.
post #140 of 3446
Thanks. I just ordered this today. Should have it in hand tomorrow. I'm really looking forward to the code release.
post #141 of 3446
just wondering why you bought the i1 display pro instead of the colomunki display?
from what's being said here, the colormunki display is a spectrometer and should be a better choice?
just curious.
thanks
post #142 of 3446
just curious.
thanks
The colormunki is not a spectrometer. It's essentially identical to the Display 3. The main difference is speed of measurements, especially dark readings. I have no idea just how much slower (I'm not putting too much faith in the 1 reviewer who said it took only 2x longer than the Display 3), so I figured I'd spring for the extra cash. Yes, I'm probably throwing money into the wind...
post #143 of 3446
ah i see. looks like i got my information wrong.
post #144 of 3446
No not really... I find it confusing too. There are two products:
http://xritephoto.com/ph_product_overview.aspx?ID=1115
and
http://www.xrite.com/product_overview.aspx?ID=1513
which are very different (photo/design is spectro, display is not).
post #145 of 3446
and
I doubt the ColorMunki Photo will compare with the Display3 in low light reading ability. For publishing work, where you need to calibrate your monitor and printer both, the ColorMunki Photo is a great product. For display calibration, I'm pretty sure the Display3 or ColorMunki Display will best it.
post #146 of 3446
Thanks for that, you're probably right i1Display3 OEM is likely correct, I'm just worried about making unconfirmred claims of support.
John
post #147 of 3446
Hi John, any update on a 'test ready' release?
I should be purchasing a colorimeter later this week. Thanks
post #148 of 3446
There's a few signing wrinkles with the driver and a couple of bugs to sort out but nothing major, probably be ready Thursday/Friday.
John
post #149 of 3446
John
That's great. Looking forward to it.
Can we still use the existing guide to perform calibration with the updated HCFR program? Or will there be a need for a new guide?
http://www.curtpalme.com/forum/viewtopic.php?t=10457
post #150 of 3446
Anything related to setting up the meter will change but the rest of it should be fine.
John
