AVS › AVS Forum › Display Devices › Display Calibration › HCFR - Open source projector and display calibration software
HCFR - Open source projector and display calibration software - Page 110
post #3271 of 3446
Originally Posted by zoyd View Post
no, I would not use the generic matrix corrections, use the appropriate display selection on the next page.
What I found interesting before using the Samsung LED entry, it was causing the low greyscale to come out a bit blue. Rather than neutral with the default setting for the i1 Display Pro.
post #3272 of 3446
The xrite driver for the i1pro has to be replaced with the argyll driver
Edited by vega509 - 2/8/14 at 2:23pm
post #3273 of 3446
vega, to get my i1 pro /dtp 94 working correctly, sometimes I'd have to choose the correct meter from the pulldown menu in HCFR - there'd sometimes be two options for each meter - e.g. xrite i1 pro or gretag macbeth i1 pro.
Not sure if this issue persists in later versions of HCFR, but it might help u.
post #3274 of 3446
Originally Posted by vega509 View Post
Can you uncheck the 5nM thing?... It's called Hi Rez Mode
That's what worked for me....
Still don't know if it's related.
post #3275 of 3446
tried it both ways, no go. I still cannot find what has changed, all worked fine last time I used it.
post #3276 of 3446
Have you tried using a different USB port? Win7 seems to allow using different drivers for each port for the same device and it will remember the driver-port-device combination.
post #3277 of 3446
Hi,
I just got a ColorMunki Display which I am now fiddling/playing with under the new HCFR.
I have a couple older Samsung CCFL LCD displays (model years 2007-2009) and am wondering which Display Type is best under the i1d3/ColorMunki Display meter configuration options. Is LCD CCFL IPS the one to go with or should I just leave it at the default of Non-Refresh display? Grayscale runs on one of the sets showed there wasn't much difference between the two settings - at least not enough for the naked eye to discern. I was also assuming that the LCD CCFL Wide Gamut option would not be the optimum choice for these displays. Any help is appreciated.
cheers,
--tom
post #3278 of 3446
I've tried all 6 with no luck. One difference I see on the system with the communication failure, when I click on calibrate, a "skip white tile calibration?" dialog appears, which does not on the working system.
Anyone else getting this dialog?
post #3279 of 3446
I believe I have a problem with the argyll driver. I've tried everything I could fing on the argyll and dispcal sites, no luck.
Got desperate, and installed hcfr 2.1 which uses the x-rite driver, everything works.
Anybody got any ideas as to how to correct the argyll driver? or know if it has a conflict with any other drivers, video etc?
post #3280 of 3446
Well,
I dl-ed the argyll driver and then used device manager to update it. Of course, I'm talking about a 8 to 10 year old XP laptop.... I"m not sure my help is relevant to your system.
One reason I have such an old system is I "need" the com port for another calibration program and com ports r getting rare.
Isn't 2.1 like so old it doesn't support i1 Display3?...
post #3281 of 3446
Well,
I'll find out soon enough .......... I have a set to calibrate for a friend this week, and I'll need both meters working to create a matrix for the i1display.
On a side note, I was in the same situation with my old laptop, needing com ports. It finally died, and I was forced to upgrade. I now use the USB to RS232 adapters, they work with everything I use, including ControlCal.
thanks again to everyone ..........
post #3282 of 3446
Originally Posted by thomasl View Post
Hi,
cheers,
--tom
Samsungs are definitely not IPS...why not try wide gamut CCFL and see if it measures considerably wider (or at all) than non-refersh type...
post #3283 of 3446
zoyd,
Thank you very much for this HCFR version.
MUCH MUCH better than the final official release.
I can finally calibrate my TV to a custom white point.
post #3284 of 3446
Originally Posted by 10k View Post
For my Samsung CMS the method I used was to open a new HCFR window, from which I then took CMS measurements. After that I enabled data editing and went into the CMS sheet and edited the readings so that they reflected the rec709 xy coordinates for primaries and secondaries. Then, based on the actual Y reading for white, I manually edited the Y reading until the target Y was achieved (luminance bar graph on bottom left) for primaries and secondaries. With that done I had an HCFR window open with correct xy coordinates and Y target for may particular display. I disabled data editing and set that window as "reference". In the table at the bottom left of the window, you will then have the target RGB readings for the correct xyY targets.
Ok, I know rec709 xy coordinates for 100% , but where do I find the xy coordinates for 75% primary and secondary colors?
post #3285 of 3446
If you know the D65 coordinate and the primary coordinates, you should be able to use linear algebra to interpolate the 75% point (assuming 75% is defined as 75% of the physical distance in that space from D65 to each respective primary).
I'd have to brush up on my linear algebra to do it, but it shouldn't be too hard. Lemme know if u can't figure it out, if I have time I'll see if I can calculate it.
post #3286 of 3446
Or, you may simply put the mouse arrow on the 75% saturation point on the CIE diagram and it will show you the reference values for that point.
post #3287 of 3446
I don't remember where I got this -- probably zoyd.
GCD_targetsv11_97-2004.xls 280k .xls file
Larry
post #3288 of 3446
Thanks - the wide gamut one is also listed as IPS actually. I'm guessing that it's fine to use the regular CCFL one for CCFL LCD panels.
--tom
post #3289 of 3446
Ha! that was the simplest way! Thanks!
Larry,, that spreadsheet seemed interesting, will have a look it later, seemed to contain a lot of stuff.
post #3290 of 3446
Some interesting debate on BT.1886 and 2.2 power gamma on the other thread.
So, how do you tell HCFR to measure/calibrate on 2.2 power ?
post #3291 of 3446
2.2 approximates BT.1886 at 10% video level for some displays but generally is too dark for near-blacks (< 5%) and too light for midtones. To calibrate to it in HCFR choose Display gamma as reference and enter 2.2 in the reference box. The target gamma line will reflect a pure power function with exponent 2.2
post #3292 of 3446
Thanks Zoyd.
post #3293 of 3446
I've slipped in two more fixes to the 3.1.0.6 package. The first has fixed the issue that vega509 was having with i1pro communication and the second fixes the wavelength scale on spectral plots for i1pro in hires mode and the JETI. Let me know if you encounter any other problems.
post #3294 of 3446
drinks are on me zoyd,
thanks
post #3295 of 3446
You are amazing, thanks for this.
How do i update? Remove and re-install or just install in place?
post #3296 of 3446
You can install over the old one.
post #3297 of 3446
thanks and sorry for petty chatter... I'm sure now either way would work.
Thanks again so much... Commercial packages are good and cheap now. I've always liked ChromaPure and would love to buy it but the reality is I'm better off with a new bulb purchase instead and resources are such that I have to make choices.
Having AVS709 and HCFR available free keeps me "in".
post #3298 of 3446
1. Relative -> Y White = Y measured.
2. Absolute w/gamma -> Color reference Y set to desired Y gamma target.
3. Absolute w/o gamma -> Color reference Y set to measured Y. (perfect gamma)
hi Zoyd, do you have a pointer to the formulas used for these?
thanks!
--tom
post #3299 of 3446
The dE formulas can be found at brucelindbloom.com, those options you quoted are for how the reference or target white is treated when converting to Lab coordinates.
post #3300 of 3446
Originally Posted by djams View Post
I am running both the old and new HCFR on win7 64bit with no issues - aside from the known problem with the i1pro.
I just downloaded HCFR and I cannot select my i1 Pro sensor in the drop down (only see 'simulated sensor'). How do I get HCFR to see my i1 Pro (the drivers are installed, because the i1 Pro works fine with Chromapure).
Thank you,
