post #1 of 1
*** Posted with the explicit permission of AVSForum.com ***
Hi Everyone,
Keeping to a steady release schedule, this time around, the new version is focused on bug fixes, optimizations and a preview of usability enhancements to come.
Download:
Zoom Player Home FREE
Zoom Player Home Professional
Zoom Player Home MAX
Premium users, you can still download your copy here.
Here are the fixes, enhancements and new features introduced since version 8.1 :
Code:
  * The Equalizer fullscreen navigation interface usage framework
    has changed.  The new design is simpler and easier than ever:
    Simply scroll up/down to reach a setting you would like to modify.
    Notice the Plus/Minus icons on the right hand side.
    The active icon is opaque and the inactive icon is transparent.
    Moving right/left switches the active state between addition and
    subtraction whilst Enter performs the action.
    New reset and enabled/disabled icons are displayed next to their
    corresponding action for additional clarity.
  * The fusion skin's control bar now supports brightness, contrast and
    saturation adjustments.
  * New Setting "Adv. Options / Interface" that controls whether the
    player's user interface is restored when loading new content while
    the player is minimized.
    player interface is brought on top of all other windows when
    switching to fullscreen.
    In previous versions, this feature was always enabled, but since it
    can cause conflicts with MadVR and there's no real benefit keeping
    this feature enabled for everyone.  It is now disabled by default.
  * New Setting "Adv. Options / Playback / Smart Play" that when enabled,
    all graph creation error messages are saved to a log file.
  * New Setting "Adv. Options / Playback / Control" that specifies that the
    Frame Advance code uses an alternative method of seeking.
    The default method is using DirectShow's "IVideoFrameStep" interface,
    The alternative method is by guesstimating the frame and performing
    a direct seek (the same method always used by the previous frame function).
  * New Setting "Adv. Options / Playback / Video" that controls whether
    The Enhanced Video Renderer (EVR) should permit dyanmic aspect ratio
    changes (usually triggered by clips captures from live TV where the
    content can switch from 4:3 to 16:9 dynamically).
    In v8.0, the default value was disabled (Dynmaic AR changes disabled).
    In v8.1, the default value was enabled (Dynmaic AR changes enabled).
  * The last play position is now saved automatically when the internal
    screen saver becomes active.
  + The navigation icons are now scaled "on-demand" and the result is cached
    to improve performance.  Some of the fullscreen navigation interfaces may
    open a bit faster thanks to this enhancement.
  + The right-click "Stream Selection sub-menu now lists audio tracks even
    if there is only one track available.
  + The information dialog's ("I" keyboard macro) format section now clearly
    labels the source, splitter, audio and video decoders used.
  + Scene-cut files saved for read-only media now use both the file name and
    date in order to distinguish between two media files of the same name, an
    increasing issue when playing blu-ray disc images.
  - The update message notifying you of a new Zoom Player version or new
    updates on the install center could appear behind the user interface if
    the user interface was set to 'Stay On Top'.
  - Saving scene-cut files for read-only media other than DVDs was broken.
  - External subtitle files with unicode file names were not listed with
    their proper name (either an empty line would be listed or '????'
    would appear instead of the actual subtitle file name.
  - When using FFDShow as the subtitle renderer and playing a media file
    with external audio track, the external audio tracks would get listed
    as subtitle track by ffdshow, breaking the 'cycle subtitle track'
    feature.
  - Closing the navigation interfaces automatically after a specified
    number of seconds would cause the navigation interfaces to close even
    if remote control commands were received.
  - When the "Playing new content moves the player window to the top" setting
    was enabled with MadVR as the video renderer, pressing play/pause caused
    MadVR to lose exclusive mode for a split second.
  - Switching to Audio Mode now hides the clock display.
  - Changing the volume level through the Equalizer fullscreen navigation
    interface did not always update the skin volume widget.
  - Changing the volume level through the player user interface while the
    Equalizer fullscreen navigation interface was visible did not update
    the equalizer navigation volume values.
  - Drag & Scroll was broken in the Equalizer preset list.
  - Fixed a crash when trying to close Zoom Player if the clock display and
    screen saver were active at the same time.
  - The information dialog's ("I" keyboard macro) format section did not
    include the splitter used for the playing media.
  - Running the Install Center with no internet connection would show
    three error messages instead of one.
  - Message dialogs could appear with the mouse cursor hidden, making it
    more difficult to dismiss them.
  - When using a language file, the default LIRC function type
    wasn't selected.
  - Cosmetical glitches in the options dialog search function.
