AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Cant find official LG 42LV5500 thread - Need help
post #1 of 2
Hello all -
I'm experiencing a issue and wanted to hear your thoughts. I've contacted LG support and they could not understand what I was trying to tell them.
The issue is that the TV's brightness appears to "Fade in" and "Fade out" when I switch between the LG Home screen and Netflix.
I have power saving mode off, and believe its due to Netflix having its own color-settings. In my case, I believe my Netflix settings (brightness) differs from the LG Set's brightness. When I switch between the two the screen adjusts.
Does anyone know a workaround to this problem? Is there a way to make Netflix use my LGTV's color settings rather than its own?
post #2 of 2
I take it that this model isn't really popular.
