Happy Valentine's Day all!
First of all, I would like to thank Al Gore for inventing the Internet
; without him doing that, we wouldn't have this awesome forum to learn from. Next I'd like to thank everyone that puts their time, knowledge, and efforts into helping others out around here, the site is truly invaluable.
Well, I finally bit the bullet and moved out of the apartment-in-the-city lifestyle and bought a house out in the burbs. I know, I know, "The burbs?....Really?" Yes really. So, now that my fiance and I are no longer confined to sharing our bedroom/office/kitchen/bathroom/theater with about 1000 square feet of space, I can finally have an actual theater room; and the fiance is happy to get my screen out of sight. Now onto the space.
The home fortunately or unfortunately, I haven't decided that yet, has a finished basement. It is a rather open floor plan down there with the only real wall separating the rooms being a closet, therefor I'm not completely restricted to certain walls. I know most people start their build threads with sketches of their idea and what not, but I haven't completely decided on the design yet and I don't know how to go about uploading a picture from sketch-up. So I have just taken pictures of the current state of the space.
I plan for the inner room dimensions to be roughly 14' wide by 18' deep with whatever ceiling height I have left after soundproofing, current ceiling height stands at 7'9" which I'm kinda bummed about but what can you do? There will be a home recording studio/equipment room located off the back of the theater.
There are several ceiling obstacles that I will have to work around, but I won't know what most of them are until I tear the room apart (which I have barely started on). I will need the AVS community's help through this as I have never taken on such a large project before and plan to do it myself. Many things I have an idea about but will still desire the input of others.
I would like to have 2 rows, but I am worried about ceiling height constraints. The riser I plan to build will be 14" high and you will have to walk on the riser to get to the rest of the theater. I have a rear door entrance to the room, plan to have a 30" wide walkway between rear wall and riser. The riser will have one stair between the floor and the top that will be centrally located in between the rear row seats, and then have a left and right walkway to the main floor and front seating (centered with screen). I know I'm already working with a low ceiling and once the soffit is in it will only make it more difficult. (This would all be easier with my sketch-up to look at, I apologize and I will work on figuring that out)
I will use the majority of the equipment from my old apartment theater, but will also be replacing some items to suit the build. Current Equipment that will be reused:
-JVC HD250
-ISCO IIIL anamorphic lens
-Cineslide transport system
-45" high 2.35 Seymore AV XD material
-iRule control
-Oppo BDP-93
-Belkin PureAV conditioner/back-up
I plan on going with at least a 9.1 system, so I will have to buy a new receiver and might as well buy new speakers (need advice on this area).
Well, on to the pictures to help everyone imagine what I am imagining. I have used a sectional sofa along with my old screen wall to mock up my plan, the room is a mess please forgive me.
This will be the theater entrance, from the bar. Currently there is no door and the "doorway" sits at 34.5" wide and 81.5" tall. So, I obviously will need to frame out a doorway and install a door.
This is the theater entry and you can see the bathroom doorway. I am thinking the best move here would be to wall up the current bathroom door and place the new bathroom door just to the right of the theater door. This way I won't have to soundproof the bathroom, if anyone has other suggestions please let them fly.
This shows the where I plan to put the screen wall and seating (seating distances, not actual spots. The rear row will butt up to the left and right walls and split down the middle for entry to the riser) Picture is taken from the door way of the Studio/Equipment Room.
This is the back of the theater from the screen wall. You can see the entry to the Studio/Equipment Room to the left, the entry to the bathroom to the right (still unsure about this one), along the right wall is the closet that separates all of the rooms in the basement (I will be removing the walls of the closet that run parallel to the theater's rear wall in order to create a wider room), and the two HVAC vents that feed the room (one is in the ceiling near the light that will be removed and the other is just left of the screen framing in a section of the ceiling that is 18.25" lower than the rest of the ceiling.).
This is the closet that I was referring to in the rambling above. As you can see I got anxious and already removed the doors and most of the innards that were there and started to pull the paneling down.
This image is taken from another "room" in the basement that my build will be invading. I will have to build a wall to divide the rooms (unevenly as I want a decent sized theater) and then build a slightly angled wall from the dividing wall to the "bonus" room's entry. It will be angled in order to not have a narrow "unwelcoming" entrance. The paneled wall in the center of the picture is part of the closet that is being removed, but I will be leaving back of the closet and angle from where it stops to the divider wall in the "bonus" room. You can also see that section of ceiling that is 18.25" lower, where the beams come to an end. I'm not 100% sure, but I believe that all that is in there is the duct that leads to the one vent, hopefully this is the case and I can just use a newer smaller flexible duct and reroute to the side of the theater in the soffit.
These are the wonderful ceiling issues that I have. Down toward the screen wall I'm not so worried about since there is no impact of the ceiling being low down there, or is there? The lowest part is what I believe to be just duct work, the next step up I have no idea about. I'm guessing it is a support beam and possibly plumbing? I won't know until I tear down these PITA ceiling tiles and drywall. Now the elephant in the room, the 4'x6'8"x5.75" rectangle, is just something I will have to work around. My current design tries to hide it as best I could think (again I need to get my sketch on here) but I don't know if I need to build the ceiling to mirror it on the other side of the theater or not? (for acoustics?)
This is what the elephant looks like from upstairs. Please forgive the mural on the wall (it was there from previous owner), we have only been in the house for about a month and just decided on a paint color, just haven't painted yet. This is to my fiance what the theater is to me, lol, so it isn't going anywhere.
This is the doorway to the Studio/Equipment Room. I will frame it to a single door operation, having the door open toward the theater and to the left. I plan to have an opening in the center of the back wall for the PJ/Lens to go from the Studio/Equipment Room to the theater room (not sure about how this would affect the acoustics of the room, again any input would be appreciated).
This is what the ceiling looks like in the Studio/Equipment Room, I assume that this is what the ceiling looks like behind those tiles in the theater room. This room was used as a "Workshop" by the previous owner. The joists are 2x12s, then plywood, then the wood flooring of the main level. When music is playing in this room and you are standing in the master bedroom (directly above) it sounds like the speakers are in the bedroom. Hopefully this will be corrected with DD+GG, insulation (don't know what I should use), and I'm still not sure if I should use clips for the ceiling or not. I know it will improve my soundproofing efforts, but will I have the height? Will it make that big of a difference?
This is another picture of the other side of the Studio/Equipment Room. As I said before, the previous owner used this room as a "Workshop", I'd hate to completely tear that workbench out so I'm planing on shortening it and re-purposing it as my desk. There is a perfect spot for the equipment rack in this room, I'll just remove those shelves and the closet doors. The wall to the right (barely in the picture) is the wall that separates the theater from the studio and where I will have the PJ/Lens.
Well, that is it for the pics for now. I briefly mentioned it in the captions, but never did in the intro, I plan to use 5/8" DD+GG. I will probably use Genie Clips for the walls, but not sure about the ceiling due to my height limitations. How big of an issue would this be? Also, I tend to see people using standard pink insulation, is that better than the type made out of recycled denim?
I'm going to work on putting the sketch on here. Please feel free to ask questions, answer questions, and throw ideas out. I apologize if this post reads odd and out of sequence I came off the mid this morning and haven't had any sleep, there is no time for sleep with so much to do around here!
-Sean
; without him doing that, we wouldn't have this awesome forum to learn from. Next I'd like to thank everyone that puts their time, knowledge, and efforts into helping others out around here, the site is truly invaluable.Well, I finally bit the bullet and moved out of the apartment-in-the-city lifestyle and bought a house out in the burbs. I know, I know, "The burbs?....Really?" Yes really. So, now that my fiance and I are no longer confined to sharing our bedroom/office/kitchen/bathroom/theater with about 1000 square feet of space, I can finally have an actual theater room; and the fiance is happy to get my screen out of sight. Now onto the space.
-JVC HD250
-iRule control
-Oppo BDP-93
-Sean
! I never thought about it's structural capability before you asked. Now you have me wondering. She (my fiance) hasn't been able to use it at full capacity yet because our hot water heater is too small and she ran out of hot water. We plan to get a tankless for her. There is a separate stand-alone shower on the other side of the master bath.
I don't really know what that is but it got me thinking about the age of your house. You should keep an eye out for asbestos as you rip that room apart.
