AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Sherwood Newcastle A-965 or Emotiva XPA-5?
post #1 of 17
Currently have a Sherwood Newcastle A-965 amp with an Integra DHC-80.2. I'm thinking about getting an Emotiva XPA-5 and xlr connectors and selling the Sherwood. I'm not necessarily looking for more power just more clarity in the sound. Any thoughts? Thanks
post #2 of 17
"Clarity" is more likely to be improved by better speakers not a different amp. But I don't know anything about Sherwood.
post #3 of 17
The Emotiva offers more power but the extra 3 dB or so is unlikely to matter for "clarity", whatever that is.
What speakers do you have, how far away do you sit, and how large is your room?
My guess is room treatment would be a better investment...
post #4 of 17
I have Goldenear Triton two towers, Supersat 50c center and Supersat 50 rears. I sit 8 or 9 feet from the front speakers. My room is a pretty big room. I've had some grounding issues with the amp and processor that I've solved. Just wonder if the Emotiva would play nicer with my Integra. Probably not worth the extra money. Room treatments would probably be good.
post #5 of 17
I think it would be a downgrade. If the sherwood is working, I would hang on to it. Plus it has 7 channels as opposed to 5.
post #6 of 17
True.. The extra 2 channels gives me future options. The Sherwood works fine just had some grounding issues with my Integra dhc-80.2. It's fine now that I got them grounded.
post #7 of 17
I have the Boston Acoustics A7200 which is a clone of the A-965. One of the first amps I had was the A7200 and then I went on an amp buying spree. I have owned amps by Parasound, Sherbourn, Bel Canto, NHT, Outlaw and Emotiva. After all these amps I found another A7200 used for a great price. I have had it for several years and have no plans to replace it. The XPA-5 has more power but I doubt it will sound any better than the A-965. Money spent on room treatments would be the wiser investment IMO.
I only have a 5.1 system and use the two additional channels for Zone2. Unless you have issues with noise the XLR connections are not going to improve SQ. So I would suggest staying with the A-965 as I feel it is an excellent amp.
Bill
post #8 of 17
Not sure why that would be better. If you want to spend money, maybe consider buying/building some bass traps? (If you room is not treated)
post #9 of 17
I just ordered a few acoustic panels to put in my room.. So I'm going to keep the Sherwood for now I think.
post #10 of 17
Curious if anyone has compared the Sherwood to the Emotiva. I've read one review online from a fellow AVS member's blog that found the Sherwood's soundfloor to be terrific. I would love to hear from the OP or others that may have experience with both amps.
Ron
PS: I currently have the Emotiva amp
post #11 of 17
Ron
Ron,
If you can find the A965 for a good price grab one. As I posted earlier in this thread I have a Boston Acoustics A7200 which is a clone of the A-965. I love this amp and (knock on wood) I have had no issues with it. Last year there were new A-965s on Amazon for I believe $599 shipped. I almost grabbed one for a back up amp but decided against it. There are very few reviews on the A-965 so it is hard to get a feel that way. The A-965 is a heavy, well built, dead quiet and a great amp. Go for it smile.gif!
http://seriousaudioblog.blogspot.com/2012/04/thoughts-on-amplifiers-generally-and.html#!/2012/04/thoughts-on-amplifiers-generally-and.html
Bill
post #12 of 17
Originally Posted by Bill Mac View Post
Ron,
Bill
Thanks Bill. I appreciate the feedback.
post #13 of 17
I'm glad you guys found some use from my blog post. Though I wish I had been able to get mine for just $600!
FWIW, I'd consider trading out my A-965 for sure for only three amps: McIntosh MC207, (assuming five channels was sufficient) Anthem Statement A5, and (assuming I could put it in another room) another ElectroVoice CPS-8.5. (I use one to drive my subwoofers. It's really an incredible piece: rated 500W/ch/4Ω/all 8 channels driven, Class D, made in Germany, and just 2RU tall. It does have two fans, though.)
The Sunfire TG-whatever is interesting on paper too, given its incredible headroom and efficiency (enough to make all that power and still carry NRTL electrical safety certification), but I'd have to be convinced by listening that its crossover distortion is as low as the A-965's. I've also never done my noise test on one. But on paper it's an interesting amp.
Another amp interesting on paper but that I don't have experience with is the "LexiCrown" (Lexicon DD-8/Crown CT8150 near-twins). I don't know how the output filter is implemented in the Harman Drivecore amps, but 125W x 8 channels in 1RU for under 10lbs with no fans is quite an achievement! That's one I'll probably buy at some point to compare with the A-965. And if it's not audibly worse, 1RU and 10lbs beats massive hulk and 80-odd pounds any day of the week!
But anything less than those amps would be a lateral move at best, and more likely a step backwards. Even the Mac and Anthem Statement two are unlikely to provide one anything except better looks and a tiny bit more headroom. Keep in mind that Dr. Rich recently called the A-965 "still state-of-the-art."
Edited by DS-21 - 12/9/12 at 5:29am
post #14 of 17
Bill
I remember that Parasound amp you had.....not sure it sounds any better than MY A7200......... smile.gif
post #15 of 17
Hey Muzz,
Long time since I've seen you post. Hope all is well smile.gif. I never did any type of decent comparison of the A52 to the A7200. I doubt there would be much if any audible difference between the two. My memory is not the best, did I sell my first A7200 to you?
Bill
post #16 of 17
Hey Muzz,
Bill
Yes, that's how I remember the Parasound, I picked up the 7200 at your house, and listened to your system for a few...
You had the Dyn. Focus speakers, with the outlaw(I think) sub(on the left), and the newly aquired Parasound amp.
I think we listened to Dyre Straits IIRC
Everything is going good here, I hope all is well on your end.
Gary
post #17 of 17
Gary
Hey Gary.
Wow redface.gif!!! That shows how bad my memory is. All that "good" living in my early years has taken its toll eek.gif. But now that you reminded me I do recall you coming to the house to pickup the A7200. I'm glad to hear the A7200 is serving you well. They are great amps without a doubt. At least you have a good memory as I did have the Focus 140s and the Outlaw LFM-1 sub (on the left). My system is totally changed and I'm real happy with the way it sounds smile.gif.
I'm glad all is well down "south" smile.gif.
Here is a picture of my room in it's present form.
Bill
