AVS › AVS Forum › Audio › DIY Speakers and Subs › Bash 300,s or dayton sa240
post #1 of 12
Simple what one would you buy?
post #2 of 12
I bought the Dayton 3 years ago and it has served me well. It has plenty of power for my smallish room. I use it to a power 12" driver in a sealed box.
post #3 of 12
post #4 of 12
Parts Express also has a 300w BASH amp along with the SA-240.
I would consider buying which one is on sale (i.e., least expensive).
I have the PE 500w BASH amp and also the PE SA-240. Both work fine in my applications.
post #5 of 12
I'm a believer in the BASH amps. Best thing I like about them is how quiet they are with no signal. No hum whatsoever. The 240 I have has a slight hum. Also, I've had some 'old school' plate amps where the huge transformer itself was a source of noise. Not a problem with the BASH amps. I do have some smaller 'old school' types (the 100W type), and they are dead quiet too. But I'm fairly certain that if I were to buy another, it'd be a BASH type. I keep a 300W and 500W spare, just in case the bug hits me to build something.
post #6 of 12
Yup, the 240 hums... Can a cheater plug help
post #7 of 12
Creative Sound has the BASH 300 on for $125!
post #8 of 12
I picked up my BASH 300 from Parts Express for $114 shipped. Not sure if that price is current.
post #9 of 12
my 240 hums as well, althought the wife makes me keep it turned down so low i don't even hear the hum ......
i was having major cable tv signal problems when i last tried turning it up and heard the hum. since then the cable stuff has been 95% resolved so maybe the hum has lessened.
can't say a Bash wouldn't do the same thing in my setup, but if i buy another plate amp i will probably give Bash a shot
-1 on the cheater plug thing... after some reading about electrical safety issues i've decided to make a significant effort to remove them from my house completely. i've changed a few 2prong recepticles to 3prong to avoid them in the past.
post #10 of 12
BASH pricing is correct as of today on PE's site...
SA 240 (and 240b) both only a few dollars more for 119.00
post #11 of 12
Yes, it resolves the hum.
post #12 of 12
If you have pets or kids I would do the same. I don't and unplug all devices prior to working on them. The chances of anything going wrong are very small as well.
