AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › BIC power cords
BIC power cords
post #1 of 7
So I have 2 BIC V1220s and a BIC F12. All three use the same power cord and all three the power cords are lose in the receptacle and like to fall out/come unplugged at the sub. Anyone else have this issue or am I just lucky? Any recommendations on a fix that won't alter sellability as I might or might not sell one or more of them? Any help would be appreciated. Thanks.
post #2 of 7
spread the prongs slightly.
post #3 of 7
I also have a V1220 that I use for my music area and yes the power cord on the back is a little loose. It is the same way on both of my BIC PL-200s. But the good thing is I have never had an issue with them falling out of the socket of the sub...no matter how hard I drive them.
post #4 of 7
kcnitro07's fall out if you just look at the subs out of the corner of your eye.
John Q it's on this end of the cord...can't spread the prongs
post #5 of 7
get one of these, http://www.monoprice.com/products/su...02&cp_id=10228, i got some, there great you can get different lengths, because i had the same problem with the power cable to my Pioneer VSX-1121, the cord was loose, there great you can get different lengths,
post #6 of 7
Spread the prongs that go into that end of the cord.
post #7 of 7
Besides lightly spreading the prongs wrap the end of the cord head with electrical tape and that will tighten up the fit also usually 2 to 3 rounds will do it.
Or find an electronics supply and get another IEC cord be sure to match they come in two flavors grounded and not grounded in various lengths.
