Originally Posted by
arnyk
Really? It does matter, because if it was zero (a permissible value according to the above) then your favorable comments about their objective test data would be a false claim.
Good grief. You know it is not zero. I know it is not zero. As a matter of fact, there is a ton of measurement data there and you know that. But you want to argue the 0% case?
The fact that the objective data in Stereophile is a minor component of the magazine is relevant, if you are going to justify them based on it.
It is not a minor component. Taking measurements is hard work and every issue has a ton of it in there.
Amir, you are obfuscating the fact that both you and Stereophile don't see any use to routine use of properly-run listening evaluations.
More examples of you fighting the daemons inside you rather than discussing the point in the thread.
Stereophile and TAS are IME about equally troubled when it comes to their subjective testing, which is the vast majority of what they both do.
Who cares? I didn't defend or talk about any subjective talk in either magazine. As I said, the pain in you runs deep and you can't have any objective discussion otherwise without letting the daemons surface this way. You are so blinded you don't see the good.
Then you are beating on a dead horse, Amir. I've made favorable references to Stereophile's objective tests in many posts that you have replied to.
Then you have no business complaining when I praise the same.
You know very well that I even use Stereophile's objective test data for my own purposes!
Here you go again, ranting and raving about my comments about a different part of the magazine, trying to confuse them with what they were not. You are polluting this forum with ranting and raving about a controversy that only exists in your mind.
I will fight people going out of their way to slam something when it is not even topic of discussion. You had no business talking about Stereophile where the report came out about TAS. You also have no business arguing when I say they have good measurement data and you confirm the same above.
This is a complete and total falsehood on your part Amir because you have replied to posts in which I have used Stereophile objective test results to support my arguments.
Why do you make false claims like these Amir? Is there any truth to be found in you when you are going off like this?
Let's talk about false claim. In anther thread, you claimed PCI Bus Contention causes fidelity problems in PC audio sound. Can you explain what the audible effect of PCI Bus Contention is?
Also, what happens if the system is not able to keep up with playback of digital audio stream? What is the audible effect?
