AVS › AVS Forum › 3D Central › 3D Displays › Passive Projector?
Passive Projector?
post #1 of 4
Anyone running passive 3d? do I need a fancy silver screen or do cheap ones work ok?
I cant find passive projectors - but did stumble accross the Tru3D Active-to-Passive 3D Polarizer
post #2 of 4
They're out there, expensive at this time. $15,000 comes to mind. LG I believe.
post #3 of 4
Most people running passive setups do it by stacking two projectors with polarizing filters in front.
The disadvantage being the only real way to drive such a system is from a PC.
Yes you need a silver screen.
post #4 of 4
Maybe LG's 84" 4K LED passive set coming out this summer will do.
  Back to Forum: 3D Displays
