YOU DON'T NEED MUCH!
Allow me to explain:
Quick info: my two fronts are B&W CM9s. Room is medium sized. Speaker placement and room acoustics are nearly perfect.
Just got a very nice Mcintosh amp w/meters for cheap.
I always knew that for normal listening you don't use much power. I didn't know it was so little though...
While listening to ANY genre of music (2 channel, keeping in mind my speakers aren't super sensitive either), I was using at MOST (during peaks) 1-2 watts. Yes, one to two. When I turned it up very loud, peaks were only hitting at very most 25-30 watts. It gets exponential from there yes, but you don't need hundreds and hundreds of watts for good sound. This seems to be a misconception here and everywhere. Most amps or receivers able to do a true 50 watts/channel continous with higher peaks than that is more than enough. Much more.
Unless that is, you want a measuring contest
