AVS › AVS Forum › Video Components › Home Theater Computers › Official Streacom thread
Official Streacom thread - Page 4
post #91 of 236
Originally Posted by StardogChampion View Post
Do your AC adapters have a 2.5mm * 5.5mm tip?
They do. Anyway, eventually I can manually modify it.
My question was more on:
- the fitting in the FC8 EVO case is ok?
- the quality of the wide range picoPSU is good or the fixed 12V ones are better?
- and most important: will 120W be sufficient for a Haswell build with only RAM and SSD (no optical drive nor discrete video card)?
Thx,
Dakkar
post #92 of 236
2.5mm * 5.5mm is the right size for use with the picoPSU.
The quality of the WI picoPSU is very good
120W is more than enough with just the CPU + SSD
post #93 of 236
Great. Thank you!
post #94 of 236
I just noticed that the wide range input picoPSU only has 20 pin atx connector (instead of 24). Can I still use it on H/Z87 motherboards?
post #95 of 236
Some of the picoPSU models have the extra 4 pin connector. Check the pictures at http://www.mini-box.com/DC-DC
post #96 of 236
so the additional 4 pin are mandatory?
post #97 of 236
The extra 4pin connector carries more 12V current for the PCIe cards. If you have no high power draw cards (gfx, raid, etc) you can get away without using the extra 4pins.
post #98 of 236
Originally Posted by Zygmunt View Post
In 11÷14 weeks, so end of November, beginning of December.
I think I will wait for those (but I will need before 10th of december, so I hope they will arrive in time...).
Some questions:
- will the custom model with no odd slot be available with short pipes?
- will the price for the new units be the same as today (160$)? (if cannot post price, please PM me...)
- can you provide a different picoPSU model like PicoPSU-120-WI-25? If so, for how much? (if cannot post price, please PM me...)
Thx,
Dakkar
post #99 of 236
Ho much Thermal paste will I need for a FC8 EVO build?
Will 3,5 grams be sufficient?
Dakkar
post #100 of 236
Some questions:
Here is a problem: Manufacturers create motherboards with CPU socket in different places. For current 1150 mini ITX motherboards three different sizes of cooling pipes are required.
Look at these motherboards:
What length of pipes should we supply with chassis? Which motherboards are the most popular here?
I think that we should supply chassis with short pipes and offer long pipes as additional accessory, so people can swap pipes when they change motherboard.
Any opinion or suggestion is welcome here.
Any MiniBox PSU can be offered by us, if there is demand for it.
Thx,
Dakkar
Regards
post #101 of 236
I would be interested in using a low-end 1150 mb like the ASRock B85M-ITX:
post #102 of 236
CPU on the right = short pipes.
post #103 of 236
Ok, so I should be able to get one FC8 EVO with no Optical Drive slot with short pipes at the end of november, right?
post #104 of 236
Regards
The Asrock Z87, that's the one I'm eyeing. I think the short pipes with long pipe option would work for everyone. But I need one with an optical disk slot, I thought that was standard on the Evo.
I'm not too familiar with Pico PSUs, but I need one that can run a 95W CPU (may downclock if thermals prove to be an issue), a couple SSD's, and an ODD. I'm not sure if I need a 120W supply or 150W.
post #105 of 236
95W TDP is in upper edge. Please remember that 95W TDP can go to 200W for short period of time, so be careful. I would rather go with 65W TDP to be safe - if you can.
Depends on applications you should consider 150 or 160W PSU and 150 W AC/DC converter IMO.
post #106 of 236
Thanks, that was just the information I was looking for. 65W it is, since it'll be on 24/7 that is probably best for thermal considerations.
post #107 of 236
Streacom designed NC1:
Designed for the Next Unit of Computing (NUC) platform, the NC1 delivers silent computing in an impossibly small package.
The case is modular, meaning that front, rear and CPU cooler can be replaced to accommodate future NUC motherboards and its acrylic sides allow for internal WiFi and Bluetooth signals to propagate, keeping the outside sleek and clutter free.
The optional VESA compatible mount allows it to be hidden behind the monitor, but with looks like this, we think most people will have it on display.
I like to know if people in the USA are interested in such chassis.
Already ten day passed and no one is interested in this chassis? I receive only two e-mails before I posted this info and one phone call yesterday not related to this post.
Is the idea to bring them to the USA, senseless?
post #108 of 236
The P4 4-pin connector is for the CPU.
I haven't met a mini-ITX motherboard yet that need a 24-pin connector. 20-pin always seems to work. I've read the extra 4-pins is to provide more power for discrete GPUs but I don't use GPUs in my systems so I cannot say.
post #109 of 236
I would say bringing an NUC inspired chassis to the states isn't worth it. There are several players already in the space, and while they are having a small amount of success, most people that buy the Streacom products are looking to do a bit more customization than is allowed by the NUC designs.
post #110 of 236
Thanks for your opinion, Life.
post #111 of 236
I will be showing some Streacom chassis on CEDIA. Please visit Assassin HTPC stand.
post #112 of 236
Hello Zygmunt,
since I am waiting for the FC8-EVO with short pipes, can you please confirm the arrival of such chassis by beginning of December?
Thx!
Dakkar
post #113 of 236
I have just seen that the FC8WS EVO (with no ODD) has changed model number to FLM7.
Is that just a new naming or has anything changed?
Thx,
Dakkar
post #114 of 236
Originally Posted by dakkar View Post
Hello Zygmunt,
Thx!
Dakkar
These chassis in black will arrive by end of October under Perfect Home Theater name. Short pipes shortly after.
post #115 of 236
Thx,
Dakkar
Streacom name will be the same, until company makes some changes.
FLM-is different brand.
Edited by Zygmunt - 11/6/13 at 1:21pm
post #116 of 236
Originally Posted by Kenks View Post
I have changed my motherboard from Gigabyte GA H87N-Wifi to Zotac H87-ITX Wifi. The difference between these two H87 1150-socket boards is that the PSU connector placement. In Gigabyte, the location is just under the cooling heatpipes in such a way that only two pipes, one per each side, can be used. On Zotac board, the PSU connector is moved paralleld to the memory slots, so the entire heat pipe side is free, 4 pipes can be used. [snip]
Hi Kenks,
I'm about to buy a fanless haswell box that is largely inspired by your setup. I'm planning to buy the following:
Type Name
Cabinet Streacom FC8B EVO Black
PSU Streacom NANO150 PSU Adapter
USB 3.0 cable Streacom SC30 USB3.0 Internal Cable
Motherboard Zotac H87-ITX Wifi
ATX 24-pin extender DELTACO extender, power cable EPS/ATX12V 15cm
CPU Intel Core i5 4670T - 2,3 gHz - 45W - LGA1150 Socket - OEM
RAM Corsair Vengeance LP DDR3-1600 DC 8GB
SSD 250 GB Samsung 840 EVO
Slim SATA cable [tbd]
I might also add the streacom bluray drive.
  • Are you still satisfied with your stuff, or is there something that I should reconsider before buying?
  • You chose a 35W CPU - I'm about to buy a 45W CPU. Do you think that a 45W CPU (with 4 cores) would function fine in the cabinet?
  • What length should the ATX power cable extender be - will 15 cm be enough?
Best Regards,
Peter
post #117 of 236
post #118 of 236
Factory sent me one set for testing. After confirmation they will build large quantity and ship part by air to let me have them ASAP for current clients.
post #119 of 236
ok, thank you. Let us "non current clients" know when the short pipes are available together with the f8c evo in one set, and I'll get one of those.
post #120 of 236
I will. It will be as an option with fanless chassis and as a part.
