AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › A shelf to go under the tv?
post #1 of 4
I'm looking for a shelf similar to this one:
http://www.amazon.com/Cambre-DW1B-BB...98179&sr=1-133
$150 seems a bit ridiculous for a simple shelf. Anyone know of one similar to that? I need it to be about the same size as that one, around 3 feet wide and 16 inches deep. The cheap shelves I've seen at Home Depot would be fine, but they are not deep enough.
post #2 of 4
Holy rip-off, Batman. That's pricy. Thgere must be plaenty more of this type on Amazon, but do Google searches on home theater or audio wall-mount shelves. There are thousands of them out there.
Even Wal-Mart has them (online, not necessarily in the stores),
Jim
post #3 of 4
check monoprice.
post #4 of 4
I've checked monoprice and amazon and other places, but I just can't find any cheaper ones that match the size I want. Most wider shelves are not deep enough to hold AV gear, or they are the single shelves that will only let you put one item on it. I have seen several stacked shelves and things like that, but I want only one shelf 3 foot wide. Might have to make my own or something.
