Note: These new models have:
Photos
7777 / 7778 spec sheet (pdf)
CM-7777, CM store
Technical Specifications
CM-7778, CM Store
If you've been thinking about a CM-7777 or 7778 with separate VHF & UHF inputs, don't wait too much longer.
- Only a single input,
- Higher NF specs
- No longer list overload specs
- A different power supply system
Photos
Single VHF/UHF input to a high quality, low noise figure broadband amplifier
CM-7777, CM store
• Combined VHF/UHF inputs
• Gain: 30 dB, 54 to 1002 MHz
• Includes a switchable FM trap
• Outdoor rated housing
• Mast mounted amplification unit with indoor power supply which connects via coaxial cable
• Preamplifier and its power supply can withstand up to 140° F temperatures
Noise Figure: ≤ 5 dB
CM-7778, CM Store
• Gain: 16 dB, 54 to 860 MHz
• Mast mounted amplification unit with indoor power supply which connect via coaxial cable
Noise Figure: ≤ 4 dB
