Originally Posted by
Nimo
Sorry I was going off pure recollection what your looking for is the file format with audiocopy. You can double check your settings in the open queue to make sure. If your going to do 2D to 3D conversions you need to put the encoder in sw mode dxva will lockup the PC.
Thanks, I tried that, and I got the same problem.
This is so odd. I must be doing something wrong with my media player, unless DVDFab is messed up. There were some issues with that happening before, but they said it was fixed.
I can get makeMKV to work but not DVDFab files in MPC.
