Hi guy,
I got a C5500 and i used Optical Quantum BD-R 25GB to burned some movies and put the disc in the C5500 it said cant read the disc and then eject by itself. And i use the same disc put in the LG BD611 and it work just fine. I wondering is cause by the discs or the Player(tried 10s discs already)
Are anyone have the same problem and got it solved. Please help.
