AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Lane Grand Slam theater seats?
post #1 of 7
Anyone have first hand knowledge with the Grand Slams? I am considering the Lane Grand Slam row of 3 theater chairs for my soon to be built home theater. I like the price point of them and also the fact they are narrow and high backed row of 3 is 91". My theater will be approx 10'8" wide when done. I am 6'2" 220lbs and just wondering if I would fit in them and are the comfortable? Also if anyone has other suggestions on seats I am open to suggestions.
Jon
post #2 of 7
Lane Grand Slam 175 is the same chair as quite popular Berkline 13175, but there are better options out there...
post #3 of 7
Roman
What would you reccomend that you guys sell?
Jon
post #4 of 7
post #5 of 7
I would like to give my review of these seats. I ordered 3 seats from Stargate Cinema in Dec 2011. After 2 calls they finally decided to ship them in Jan 2012. When they arrived one seat had a bad motor so I called right away for a replacement. As of today haven't received it. There is a small PC board in the wiring harness and it was bad.
The seats are comfy for my 5'9" frame and my wife loves the fit also. She's 5'4". I ordered the seats as individuals and removed the arms for the configuration I now have. That way I have 2 extra arms for parts. We are getting butt marks in the padding and don't know if that is a sign of things to come. I only weigh 183lbs.
Because I removed some arms I was able to see the Chinese build quality and it is typical of what I see in everything built there. The holes are ground out if they don't line up. The bolts are cheap and the paint underneath looks toxic.They use stacked washers a lot also.
With all that being said, I can keep an eye on things and being a welder I can hopefully fix it before it goes bad.
post #6 of 7
Not 1 hour after my post I was contacted by Stargate as to the status of my replacement parts. They were very apologetic for the problems I was having and took full responsibility for it. Rare thing these days.
I received NOT 1 but 2 motors for my seats! So if anything goes wrong I'm set.
To update my review of the seats themselves. I'm missing a lot of movies now because I keep falling asleep half way thru them. I looked over the other night and the wife was snoring too Might have to get the butt kickers
How to properly review a move - If someone dies in the first 60 seconds it gona be good!
post #7 of 7
I would recommend the Lagoons from Roman. Same as the Lanes. I have 5 of them in my theater and love them. I am 6'3" and 280lbs and they are very comfortable and supportive.
