I have the opportunity to obtain an AV15H driver and am contemplating a sealed build. I attempted to plug the values into WinIsd, but got an error msg when I tried to save it. Can someone help me out with modelling this?
I plan on doing 3-3.5 cubes and use an EP4000. In all my research, I've gotten some conflicting info on the amount of power to be used in that sized box.
Just some quick background: I'm currently running a SVS PB10 alongside a Velodyne DPS-12 in about a 2000 cubes sealed room. It gets loud to my ears, but I would like more SPL and deeper extension. I just helped my brother with his Shiva-X in 3.5 cu sealed build and that definitely has deeper extension than I get with my pair. Will I be able to outdo both sub-stages with the AV?
Finally, I have some very potent mains that play down to 25Hz or so (Noussaine measurements, not mfg specs) so can cross at 60 with no problem if need be.
Thanks for any help you can provide.
AV15H - D2 - coils in parallel
Fs: 22Hz
Qms: 4.86
Vas: 197L
Cms: .22mm/N
Mms: 235g
Rms: 6.7kg/s
Xmax: 23mm
Sd: 794sqcm
Qes: .29
Re: .68
Le: .07mH
Z: 1ohm
Bl: 8.8Tm
Pe: 1000W
Qts: .27
1W SPL: 90.7dB
2.83V: 101.3dB
Fs: 22Hz
Qms: 4.86
Vas: 197L
Cms: .22mm/N
Mms: 235g
Rms: 6.7kg/s
Xmax: 23mm
Sd: 794sqcm
Qes: .29
Re: .68
Le: .07mH
Z: 1ohm
Bl: 8.8Tm
Pe: 1000W
Qts: .27
1W SPL: 90.7dB
2.83V: 101.3dB
