AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Yamaha RX-V3900 help please !
post #1 of 2
I am running HDMI from set top box into RX-V3900 - pass through works great. Up-scaling works great when unit is powered on.
Here is the question. Is it possible and if so what are the correct settings for:
Viewing (On the Display) set top box signal with the RX-V3900 power on and also listening to USB / Net all in the same "Zone"?
Example : Watch the basketball game while listening The Eagle Classic Rock
Hope someone has a answer - prior to running the set top box through the Yamaha - I could do this, obviously, no problem - but now can't do it. If I am watching the television and than select the USB / Net button yes I do hear the music but loose the television picture.
Thank you for any help you can over!
post #2 of 2
You can't listen to an audio only source while switched to a video source. I realize past receivers allowed this, but the feature seems absent with newer models.
I know there's a reason of sorts, but I would have to think about why the change was made (you could accomplish it maybe by using zones, with another set of speakers.)
