AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Receivers with inbuilt support for PAL to NTSC conversion
post #1 of 4
Are there receivers that support a HDMI input @50 HZ and output @60 HZ. That woudl solve a big problem I have which is too take a 65" TV back to India..
thanks in advance..
post #2 of 4
thanks in advance..
If all you are going to watch are DVDs how about a universal DVD player. I haven't heard of any avr's doing this.
post #3 of 4
Have look at the NAD receivere. I vaguely remember there was a bug where they were outputting HDMI at a specific setting- it may be 60hz.
post #4 of 4
Check with the brand/model..
I can tell you that majority of the AVRs auto-detect PAL or NTSC streams and have built-in capability for both. This is done to have more commonality with global markets, but again verify this with your target brand/model.
Hopefully you are aware there are also differences for AC line voltage/frequency and FM/AM tuner channel spacing as well..
Just my $0.02....
