Originally Posted by
cel4145
I change my mind constantly as to which I would think I would like best if I had all three in the room. Depends on what rubric you grade these subs by. And I'm actually influenced by thinking I will eventually have dual subs. So what's best for that situation.
If you intend to go multiple subs and are building a setup for the long term, I would look at getting some sealed subs, depending on your room. The gradual low-end roll off from sealed could add up better to give you higher deep frequency output than if you went for ported subs. Think Hsu ULS-15, Rythmik F15, SVS SB13, multiples of those would negate the advantages of their ported brothers.
cel4145
Right now, I'm thinking the SVS because of the flat frequency curve and the low distortion. I agree that the EX has more output. However to get the EX fairly flat with an EQ, you'd lose a lot of that extra output from 30hz on up (unless room gain gave you a bunch of boost in the lower frequencies).
You don't lose the headroom from the Outlaw by EQing it, it is always there available to you. If you turn the volume up past its 20 hz limits, it will get louder, but just not at 20 hz. Also keep in mind that the Outlaw's FR is actually relatively flat, not as ruler flat as the PB12 but better than most subs.
cel4145
But I'm sure I'll change my mind again in another few weeks. And no. I will not be buying an SVS or HSU if I go dual, but another EX
Get two of those, set them up for front-firing and run them in max output mode is my advice, my god will those things pound, just brutal bass. And the closer you position them to you, the better it gets. Play some Drum'n'bass or dubstep with the subs running 6 db hot, that is an experience to behold, bass nirvana.
