Originally Posted by Steve1981
Well I disagree with your disagreement
http://en.wikipedia.org/wiki/Clippin..._processing%29
In this case, the threshold exceeded is simply the maximum output designated by the engineers at SVS; since the limiter obviously limits the signal after the threshold is exceeded, the signal is clipped.
EDIT:
Also, regarding clipping amplifiers:
http://sound.westhost.com/clipping.htm
EDIT:
A limiter is nothing but an automated volume control though. If we were prescient and really fast we could do exactly what the limiter does by adjusting the volume control on the back of the sub. That's not clipping anything, it's adjusting the volume control.
I don't much care how you define clipping, but turning down the volume does not equal clipping under any definition of the term. Otherwise it would make sense for me to say "my amp was distorting, so I clipped the input signal to reduce the distortion." Nonsense.
I don't want to go round and round on this and you can educate yourself on the meaning of clipping if you want to. But it's impossible to have rational conversations when we take part of the definition of a word and then twist it to mean something it doesn't.
So if you want to use a limiter to keep an amp frome distorting, you set the limiter to kick in BEFORE the level gets to the level of distiortion. Then the signal is kept within the range that the amplifier can handle without clipping. You would not design the circuit to start limiting after it's too late. The amp doesn't clip (and I'll stand by my admittedly shorthand version of the definition - - every amp in the world starts distorting the signal at some point in its power curve, but we do not call it clipping until it reaches whatever THD level we've decided to use for "clipping." Wander over to Stereophile.com and look at the measurements sections of a few amp reviews, and I think you'll quickly see what I'm talking about.
