AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Help - Echo in speakers
post #1 of 17
Hi, thanks for reading my post.
I am experiencing an echo on lower frequency sounds. For example, if music is playing on a movie, I'll hear the bass normally, then about two beats later, I'll hear it echo at a lower volume.
I have the cable box and xbox connected to a Pioneer VSX-821 via HDMI cables, and a single HDMI cable running out of the receiver to the TV. Suggestions are appreciated.
post #2 of 17
Never heard of that. What kind of speakers do you have?
what sound mode are you using on your receiver?
post #3 of 17
Are the TV speakers playing along with your stereo/surround?
post #4 of 17
Exactly what I thought when I saw his post.
post #5 of 17
TV speakers are disabled. I have 2 floor speakers, a center speaker, and 2 rear shelf speakers. I hear the echo no matter what mode the receiver is in.
post #6 of 17
Try adjusting the sound in the cable box menu and see if that takes care of it.
post #7 of 17
Doesn't sound like a speaker related problem...
post #8 of 17
Maybe the L/R surround delay setting is too high...
Just my $0.02...
post #9 of 17
Just my $0.02...
That seems like a good guess. On my receiver, there's a speaker distance setting for each channel. What that really is, is an audio delay. If that's not set properly you could definitely experience an echo.
post #10 of 17
Lifted from the Dolby standards....
"The Dolby specification is 15ms and the product should allow delay adjustment of 0-15 ms for the surround channels, in steps of 1 ms or less. Steps of 1 ms are recommended. As indicated previously, the adjustment may be provided using speaker distance information..."
Another thought...
If set by the Room EQ S/W there could have been an error during the setup routine..
Just my $0.02..
post #11 of 17
1 more thought..
Many users are unaware that also when in Dolby True Audio the L/R fronts have a Time Delay applied as well..
"Front Time Delay
If adjustable surround delay time is included, the product should provide delay adjustment of –2 to +7 ms for the front channels, in steps of 1 ms or less. Negative delay adjustments are used for front channel outputs that are farther away from the listener than the L and R speakers (allowing them to respond ahead of other front channels to compensate for their physical positions).... "
Just my $0.02...
post #12 of 17
Thanks for the suggestions. My delay was originally set to 0ms. When I changed it to 1ms, the echo disappeared. I don't understand why, but it worked!
post #13 of 17
I don't understand either. 1ms is too short an interval to be discerned as an echo.
post #14 of 17
You're right, the echo I heard was more than 1ms. It was more like half a second. If a song ended abruptly, I would generally hear the last two beats of the song echo. If a deep voice stopped talking, I would hear the last couple of words again, only muffled a bit.
post #15 of 17
Hi blaine84, I'm having the same problem with my new Pioneer Elite VSX-40 receiver. You mentioned you have 5 speakers (no subwoofer). I also do not have a subwoofer and in the setup I have Subwoofer set to NO and my mains (L+R) set to LARGE. I found if I set Subwoofer to YES, the echo goes away! However, this is not a feasible solution since the LFE channel is not redirected to the LARGE L+R speakers. Could you tell me which setting you adjusted to get rid of the echo?
post #16 of 17
I changed S.Delay from 0.0 to 0.1.
post #17 of 17
Thanks, that seems to have done the trick! I also had to set it individually for each input.
