Originally Posted by Spoliator
I was one of the first to comment on the Netflix audio issue, and the one who came up with the BD Live fix.
Ultimately I found that shutting off BD Live didn't prevent the audio lag all the time. If certain discs were played even with BD Live off, the audio lag would return.
My solution was to exchange my 320 for a new one. I've had no problems at all with the replacement. One thing I did do differently with the replacement, however, was that I did the initial firmware upgrade using a CD-R instead of directly over the internet.
Wow, that sounds like voodoo, no offense.
? If you bought it believing that you would keep it and return it because you don't like it without claiming that it's broken, accepting whatever return shipping or restocking fee hit that entails, I don't see any ethical problem. Retailers and e-tailers which have no risk, return-for-any-reason policies and fully expect people to return things simply because they don't like them once they've tried them.
) statements that either everything should be left off or on zero, or that the Chroma setting should be advanced thus activating some sort of better deinterlacing and that the sharpness/super resolution settings should be at various + values. Others say all this will just add noise to the image and otherwise ruin it. The owner's manual and on-screen guide are useless. Haven't had enough time to experiment.
