Originally Posted by joeltbay
Ok, now I am wondering if I made a mistake buying the 320. I've had it since April 13th and never had a problem. All Blu-Rays and any videos played off USB have been perfect.
That was until I tried Star Wars Episode IV from the blu-ray box set. Since I first posted about this problem (no audio problems, just skipping frames randomly in the video causing judder) I have tried everything - 24p ON / OFF, other enhancements ON / OFF, firmware for the 320 (it was up to date), my receiver (update was available), and my TV (it was up to date). I even looked into turning off any video processing on my receiver to make sure it was not causing problems. Nothing worked.
So tonight, I got my BDT-100 out of the box downstairs, swapped out the 320, and once again perfection. Not a single judder or skipped frame. Beautiful. Watched for over an hour looking for any defect. None. Can't watch 5 minutes without a problem on the 320. If I rewind and rewatch, there might be no problem in the same spot, but somewhere else. Like the 320 is tripping over itself trying to handle the video and gets overwhelmed or something.
I might think I have a defective unit, but everything else I have thrown at it plays perfectly. I know many problems have been reported with the Star Wars Blu Rays, but why do they play perfectly on my 100.
I would expect the 320 to have faster, more powerful processing than the 100... but does it? Are they using cheaper components? Or do I have a lemon.
Now what?
Now what?
It may be your disk and not the player. I have a BDP-320 and the Star Wars series contains several reference points that I typically throw at a system. I did not watch any extended portions of the disks but had no problems.
I'm perplexed, particularly since this is the only problem you have seen, especially since it does not occur at the same time on the disk.
Good luck!
