I can't see how that would help--you're just shifting decoding of Netflix's DD+ to the BD player. How is it likely that the BD player won't decode the same phenomena you're hearing such that it's audible to you in the PCM output? You've said that you can't hear it in DD+ converted to DD--you could always set the encoded audio output to Bitstream and then turn BD Secondary Audio on, which will get the advance DD formats output as basic DD and the advanced DTS formats output as basic DTS. Of course, that's not very desirable for BD audio.Originally Posted by morty343
Apparently another workaround is to set the player's output to PCM. Can anyone tell me if this will lead to equivalent audio quality when choosing 7.1 audio codecs on BDs, as compared to bitstream? I like the assurance of using bitstream and seeing the relevant codec type being displayed on my AVR, rather than just seeing "Multi Ch In" when it's receiving PCM.
Also note that for the 220, the maximum PCM output you'll get out of the Dolby formats is 5.1; apparently it will decode the DTS formats into 5.1, 6.1 or 7.1 PCM as encoded.
