AVS › AVS Forum › Audio › Speakers › Suggestions for speakers...
post #1 of 5
Budget is about 1200 for fronts and rears...
I've looked at Polks and Klipsch...
Going to go with a outlaw or rhymik sub...
All responses are appreciated.
post #2 of 5
almost 200 views and no suggestions from folks.....
post #3 of 5
I just picked up a 5.0 Boston acoustics VS series (4 x vs 260 and a vs 325 center) from Vann's (their on a great discount right now)
It runs slightly over your budget ($1280) and you'll need a sub and a good receiver for it, but is a very good deal going on.
post #4 of 5
madhuski:
Thanks for the head sup..... most likely going with the denon 2112ci....
I will check out those....
id prefer to have floor standing for the fronts... I see the 260's are bookshelf....
post #5 of 5
Probably because there are literally hundreds of similar threads like this one.
Take a listen to as many brands as you can PSB Speakers PAradigm Totem B&W. (I am not a fan of Polk or klipsch) There are literally hundreds of different speakers that would be great with your budjet.
-k
  Back to Forum: Speakers
