AVS › AVS Forum › Audio › Audio theory, Setup and Chat › External amp vs AVR
External amp vs AVR - Page 2
post #31 of 57
" Within their limits " So many parts involved in a good quality amp that allows it to operate within it limits. Bridge recifiers, transformers, filter caps, output transistors.....Preamp boards......
What you don't seem to get is the fact that many of those things are commodity items these days. Bryston doesn't pay 20-40 times more than Behringer for bridge rectifiers, filter caps, circuit boards, or output transistors in like-rated power amps.
Let's be clear about this:
Bryston 14B-SST2 $9.550
Power Output: 600 watts per channel into 8 ohms; 900 watts per channel into 4 ohms No 2 ohm rating.
Behringer EP4000 $349
8 Ω per channel 550 W
4 Ω per channel 950 W
2 Ω per channel 1250 W
$9,550 / $349 = 27.4
So here's the question - can anybody do a DBT where they sound different a statistically significant number of times? Does anybody seriously think that anything but the Bryston front panel costs 27.4 times more as it comes onto the factory assembly area?
Wall voltage, current can kill performence
So goes the pitch for power conditioners, which are for 99% of all audiophiles, just another waste of money. A good power amp has a good enough power supply that it is largely independent of what comes out of the wall plate. Some modern amps will meet spec with any line voltage from 90 to 250.
post #32 of 57
^^^ Your comparison of amplifiers seems a bit on the extreme side of things. But if you must, at least compare retail to retail. The EP4000 is $740. That brings your ratio down to 12.9.
And altho I'm not wealthy enough to spend $10K on a 2 channel amplifier, I have tried the pro amp route (A500) and now house a Parasound in my equipment stand. My other family members cant hear a difference but I can.
post #33 of 57
I paid $380 for my EP4000 and there were less expensive sources I didn't know about.
post #34 of 57
Compare purchase price to purchase price. A quick Google on the Bryston Shows $8995. The Behringer EP4000 is $349.
The math shows 1:25.7 ratio
post #35 of 57
What part regarding "retail to retail" didn't you two understand? Arnyk quoted retail on the Bryston and the discounted price for the Behringer. Lets keep things in perspective here.
My own "quick google" showed me a site selling the Bryston for $7200. And if I bought one at my local A/V shop for $5970, would that factor in?
If you or I had vasts amounts of money to spend on audio equipment and purchased a pair of say, Paradigm Signature S8's, what amplifier would you choose to power them with? And dont say "A Behringer EP4000" because I know you'd be lyin'.
post #36 of 57
I like cool looking and beautiful equipment. I think the emotiva is very pleasing aesthetically except for the bright lights. I also abhor fan noise in the room. Up front I don't know what i would choose at the moment. Visible in the back of the room I would rather have a stack of emotivas or outlaws or atis or something than a stack of behringer eps. Hidden in an equipment closet I'd likely choose from any number of well measuring prosound amps.
Then again, if I had vast amounts of money I would never consider the signature s8's, or any other speaker you could buy for that matter.
post #37 of 57
I'll play ball with what ever pricing games you want to play:
I picked up a Behringer EP2500 (same as the 4000) for $125 in box locally.
$5600 / $125 = 1:44.8
Plus I will answer your question about what amp I would use. And no I'm not lying:
I would take the $8K that the Paradigm S8's seem to cost with the $7200 that the Bryston seems to reasonably cost and with the subsequent $15,200 I would pick up a pair of RBH Sound Signature T-30LSE, an Emotiva XPA2 and THEN commence wiping the floor with the Paradigm/Bryston combo. Because dollars to donuts that is exactly what will probably happen.
post #38 of 57
W
I can work with that.
$7200/$349 = 20.6. 20x is still ridiculous.
post #39 of 57
So why so many different cars if they all get you to work, really ?
post #40 of 57
Originally Posted by bob_m10 View Post
Onkyo TX-NR1009: AVR
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 116.5 watts
1% distortion at 131.2 watts
Integra DTA-70.1 Amplifier:
0.1% distortion at 119.1 watts
1% distortion at 137.7 watts
Buying by the numbers eh.
Given the same distortion numbers, I'd say they are biased the same, therefore generate a comparable amount of heat, which leaves mounting placement and heatsink surface(s) will dictate how well it dissipate heat.
Is this just a brain teaser or are your contemplating going separates, because there are other more pressing items than heat if you thinking separates like more$$$.
post #41 of 57
Not at all, just trying to understand the equipment and the testing procedures. Seems from reading the thread there is not any sq differnce but there may be durability advantages to seperates. Thanks Bob
post #42 of 57
What does cars have to do with amps???
post #43 of 57
OMG, are you for real? What pricing game? I said "RETAIL TO RETAIL".
Now you bring an older Behringer model into the mix that you picked up cheap and now throw that into the equation? Should I bring Brystons 14BSST into this and then we can keep going and going....*face palm*
And I never asked you what speakers to purchase.....I asked what amp you would purchase in that scenario. Pretty simple.
But good god man, if you want to purchase $15K speakers and "wipe up the floor" against a B/P system, then don't let us hold you back. It doesn't bother me.
post #44 of 57
A $100K Corvette Z06 will get you to work just like a $10K Hyundai Accent....both can drive you to the supermarket, take you to your favorite restaurant and visit the the inlaws on the weekend. No difference really.
I mean if we're comparing apples to apples.
post #45 of 57
If I really have to answer this it says a lot about your ability to evaluate the differences.
Cars are design around many criteria. That is why you have sports cars, pony cars, hotrods, touring cars, SUVs, SAV, and so on. All are design to meet a very specific market desire. However, HiFi amps have the same set of goals to have a flat power response across the audio band, drive loads within a standard value (most speakers or 4 to 8 ohms) to have a inaudible level of distortion, to run off the same input voltage, etc… The design criteria while achieved thru different designs all point to the same set of goals. Amps and cars are nothing alike and if you don’t believe me go listen to your car!
post #46 of 57
Simple, the differences in automotive performance and opulence are vast in comparison to the differences in power amplifier sound quality.
A mid-sized, mid-priced car runs about $25K. Very very few cars run more than $100,000. That is only a 4:1 range.
post #47 of 57
Your comparison includes only a few of the relevant characteristics of cars.
Your comparison is also seriously wrong on price, because according to the Hyundai web site the Accent runs from about $12,500 to $16,000. According to the Corvette Z06 web site, it starts at $76,000.
You should be ashamed of making all these mistakes!
post #48 of 57
Your assuming everyone that drives or purchases a Corvette lives and buys in the USA.....Yosh doesnt.
Check foreign pricing......no mistake......then look up this word "Tax"
post #49 of 57
Lol I thought you guys would respond in this manner....I guess its ok to compare a very high end amplifier with one of the cheapest ones on the market and say theres no difference. If a $9K amp has the same audio characteristics as a $350 one, maybe you should let Bryston know they have a strong competitor.
I'm sure you'll let it slide since your prices were misaligned as well. And just a fyi, a loaded Z06 here in Canada will sticker for over $90K plus taxes. Maybe over MSRP but thats what the dealer can get away with.
post #50 of 57
A $100K Hyundai Accent with a Corvette Z06 fiberglass body will get you to work just like a $10K Hyundai Accent....both can drive you to the supermarket, take you to your favorite restaurant and visit the the inlaws on the weekend. No difference really.
Fixed.
post #51 of 57
Originally Posted by Bigus View Post
Fixed.
Lol, nice!
post #52 of 57
You mean that you intentionally inserted all of those significant errors into your false claims for me to correct? Pretty strange!
Of course I never said that there was no difference between the two amps. For one thing, the Bryston comes a lot closer to being a piece of audio sculpture than the fairly industrial-looking Behringer. Its build quality would probably impress many naive people. It might even perform a little better on the test bench.
It appears to me that Bryston are actually quite skilled at marketing and need no assistance from me. Selling a power amp for upwards of 20 times more cash than a sonically equivalent product is really quite an impressive feat of marketing!
This is a U.S. based forum and so its natural reference for prices is the US. You said nothing about Canada in your post. So now you are resorting to ambush tactics to cover up your claims, which BTW have changed significantly even just within the context of Canadian prices since I started scrutinizing them.
post #53 of 57
You most certainly said "Retail to Retail". I picked up an EP2500, that when you remove the cover is identical to the EP4000, for $125. Included warranty even.
The EP2500 = EP4000. Just like when Lexicon rebadged the Oppo. A new silkscreen on the front of a product does not a new product make.
Well, you mentioned a few things:
1. Speakers
2. Amps
3. Costs
I believe that since those particular cans of worms were opened that a reformulation of the above is fair game.
Unless you want to postulate that $8K speakers driven with $7K of amp is going to out class $14K of speaker driven by $800 of amp.
post #54 of 57
Why do car analogs come up in amplification threads? There are tangible, measurable, metrics involved with cars and all can be interpreted one way or another based on consumer need.
You can say a Z06 does a quarter mile quicker than a Prius. You can say a Prius gets better fuel economy. Depending on what type of driver you are you may want the Corvette or you may want the Prius.
Trying to say the Bryston is a Z06 to something like the Emotiva XPA-2 is to a Hyundia Elantra is just absurd.
post #55 of 57
You said nothing about Canada in your post. So now you are resorting to ambush tactics to cover up your claims.
I wasn't going to reply and pick apart your post like you and Jujitsu did mine.....I'm sure it gives you two a feeling of self worth.
But I thought it was kind of funny that you think I was resorting to ambush tactics when my location clearly states I'm from Canada.....its quite clear that didn't register with you considering this is a good ol' U.S. of A. site.
post #56 of 57
Sorry about laying the Jujitsu down. When everything is distilled down we are talking about a certain range of $$. Simply offering up that SQ, just might be, 95% in the speakers. Just back them with competent, reasonable cost electronics.
post #57 of 57
You are obfuscating the fact that even if the context is Canada, your price information was wrong.
More like irritation due to your post's distortions and dissembling which now appear to be habitual.
