AVS › AVS Forum › A/V Control & Automation › Home Automation › options on simple Home Theater Automation
post #1 of 3
Hi
does anybody have any ideas on simple dedicated one room automation systems, we currently use Control4 or Global Cache and ipad but it just seems like there has to be another simple solution to combine all home theater services onto ipad.... what are you guys currently using?
post #2 of 3
I use Bitwise: http://www.bitwisecontrols.com/touch.php
The iPhone and iPad app are incredible!
The programming software is very to easy to use for creating simple macros to control all of your home theater equipment with the push of one button.
Unfortunately, I believe they have to be purchased from a dealer now.
post #3 of 3
Search AVS for iRule and CommandFusion.
  Back to Forum: Home Automation
