Originally Posted by
Kimeran
A budget really hasnt been established yet because of the fact that I am not really sure what an appropriate budget would be.
However, I can share with you my goals of the build.
Obviously the fist is sensitivity. I would like to keep it around 95db/w1/1m or higher....however I dont want to go lower than 93db.
Some idea for the 3 LCR units would help. What's your absolute max?
Kimeran
I listen to alot of music so Music reproduction is more important to reproduce well but I still want them to be good for movies.
If a speaker can do music well, and doesn't give up dynamic range and dynamic contrast then it will also do very well for movies.
Kimeran
My idea for the monitor with the SEAS exotic driver was for a MTW design with a ribbon tweeter as from my experience mids on top are very good for imaging and soundstage. I am also hopping that I could do a MTW design for a center and have the same inside space but different outer shape....thinner and wider.
HE ribbons are tall, so to have a vertical TM, any height limitations for the centre will be determined by that.
Kimeran
I provided the multiple options because of the fact that I did not know which way would be better than another....I have never had horns nor ribbons but I have read so much about the ribbons that I really want to try some....and a horn may not fit in the space I have....it is in a built in entertainment center that was in the house when we moved in....
Kimeran
I am also hesitant about the horns becuase it would be difficult to make a center out of a horn with a different shape to go under a tv better.....but would a MTW center have the same lobbing issues as other designs?
See above: most suitable WGs will be of a similar height to a HE ribbon, but much wider so making the W placement difficult.
Kimeran
I will look at those other driver that you suggested.
also, what are some good ribbons that want cost me my soul? RAAL and LCY are really pricey. I saw the other ones on parts express but i do not know how good they are.
Also Fountek NeoPro5i. A couple of years ago Penn had a 3 way build with this as HF driver.
The reason I suggested the Zaph WG was that he measured a bunch of no domes and generally found them wanting. Details on his site. If you want them though, take the same pair of B&C drivers and add the NeoPro5i above them.
Kimeran
Edit: I forgot to add that I do not care too much about extension into those lower regions....its always nice....but I prefer the use of a subwoofer so as long as it goes to 60-70hz I am happy.
Still do not skinp and use a smaller driver here. Larger and still of great quality will get you reduced excursion and consequently less distortion where it is really audible.
I have a friend with a PHL based 18/10/6.5/dome active ssytem that can play so loud and clean it is possible to overdo it in a way I've heard only a couple of systems do. It would be terrific in an HT, but he is 100% 2ch music.
After trying lots of 'audiophile' drivers and comparing them to the great pro drivers, I doubt I would ever go back. Audiophile stuff sounds constipated.
