I am ejecting my 32 in Sony CRT and looking to get first flat panel. My most serious limitation is that I need to get it at BB due to gift cards...(credit card rewards put to good use).
I am leaning toward plasmas to get most bang for my buck. My budget is $700-900 if possible. Prefer 46-51 inch. 3D/Internet are "gravy" but not at the top of my priorities. For Living Room, windows off to the side, not behind the viewer, so glare may be (minor) issue. Most TV watching in evening. Seating distance will be 8+ feet. Sound not a major issue as I have sound system.
I am leaning strongly toward Sam PN51D550. BB has held this at $900 for past few months. I will likely not use 3d, but the lower model PN51D530 seems to have issues with it suddenly stopping.
I could save a few bucks and go with Sam PN51D490, which is only 720p, but I don't want to kick myself later wishing I went 1080p.
I really liked the Pan ST30, but was not able to get the $729 deal at BB, as they are all gone. (I'm not interested in display model).
Only other option appears to be LG 50PV400 ($750) which is not 3D. Again, not big deal for me if it otherwise gives good performance.
You guys are the best. Thanks for any input!
