AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Read/Write EDID
Read/Write EDID
post #1 of 6
I'm looking for software that I can use to:
1) Read EDID information from an HDMI source.
2) Edit the EDID information.
3) Output the updated EDID through the computer's HDMI output.
1 & 2 are pretty straight forward, so I really need something to do 3.
Is there any software out there that can do this?
post #2 of 6
EDIDs are read from sinks, not sources. EDID stands for Enhanced Display Identification Data.
EDID transmission is one way, from sink to source.
post #3 of 6
Hi Colm. I understand that, but I have an EDID capture device (HDMI detective) that I want to write to. I will then use that device to output the newly created EDID.
The device only has HDMI inputs/outputs. I'd like to output an EDID from a computer to emulate a signal that would come from a display that the device could capture.
post #4 of 6
Look at www.gefen.com. They have some EDID tools.
post #5 of 6
Unfortunately they don't have utilities that can update their HDMI Detective. I tried using PowerStrip to do this, but I got an error. I mentioned this to Gefen, and I have sent my unit back, and they will upgrade the firmware so that PowerStrip will work.
I've also found another product, in case anyone wants a simpler method of doing this. DR HDMI allows you to read from a source, and also has a utility where you can read/edit/write to the device. Works great.
post #6 of 6
It appears there's also a GNU/Linux utility that can write EDID's https://github.com/bulletmark/edid-rw
I stumbled upon it here:
http://ubuntuforums.org/showthread.php?t=2008395
Didn't experiment with it though.
  Back to Forum: Tweaks and Do-It-Yourself
