AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › FBr on the X3 Series ???
post #1 of 2
I just picked up two 42X3's and was wondering if they can experience the fluctuating brightness issue? My 65GT30 did and a Panny Tech did the SD Card fix. I am running the slides right now and do not have a source plugged in. They are both June 2011 builds and the serial number sequence is MB1171XXXX. Thanks in advance...
post #2 of 2
The FBR issue is more common with the higher end NEO PDP's.
Ian
