I am slowly converting my basement into a theater and after 1 year of having the screen hanging on the front wall I have decided to build a stage...I know a little backwards but the room was previously finished for a few years before I started the theater project.
As you can see in the pics I have steps that lead from the basement to the main floor of the house...which obviously cannot be moved.
What I need help with, is incorporating the steps into the stage.
I plan to re-carpet the entire room so no need to salvage the carpet.
The total width is 12'8" and I will need 14" in height to incorporate 2 steps into the stage. The 3rd step up which is also the landing will get cut back to be flush with the wall so that it does not protrude into the room as it does now.
Being that my sub is also in the front I will need to make sure that the center portion of the stage is only 1 step high so the sub will fit somwhere under the screen but ontop of the stage.
I also plan on moving the screen up on the wall approximately 2 inches to, because I think it is too low and to also give me a little more room to fit the sub under the screen.
Any help or suggestions would be greatly appreciated.
