Had to do it a difficult way because there is a window sill in the way where the screen comes down but with Vapex's help (Dave you rock) we found a way.
We mounted two 10ft 2x4s on top of eachother on the wall, each secured differently with 5.5" lag bolts. I hung on it myself so I know that sucker is secured. Then we mounted the screen to the 2x4s. It was extremely difficult to screw in the screws of the "L" brackets into the wood. But we got it up there!
Attachment 238003
Attachment 238003
. Are you happy with it so far? What made you go with this screen over any others? Would love to hear your feedback. Thanks
