Originally Posted by
BSpecialist
A little background: Bought the UN40EH6030 from BB right before black friday. I was under the impression it was 120Hz but many revealed the panel is only a 60Hz. There is much discussion that it
must be 120Hz to display 3d content. I don't understand much of the mumbo jumbo such as "pull down" or how to check in what ratio the TV is performing this "pull down." After talking to Samsung online several times (some telling me it's 240Hz, some telling me it's 60Hz but has the capabilities to convert to 120Hz. I don't know if any of that is possible...but I got a totally different response from this last conversation with Samsung. Can anyone let me know if this guy could possibly know what he is talking about? I was really hoping this was a 120Hz TV when I bought it...so hopefully someone can confirm these settings actually enable 120Hz.
Rod: Hi, thanks for reaching out to Samsung Technical Support. How can I help you today?
You: Hello, my TV is advertised as 120Hz, but in the service menu it says it only has a 60Hz panel. Why is this?
Rod: Thank you for bringing this to our attention.
Rod: Let me check that one for you.
Rod: Please give me a minute or two.
You: sure thing
Rod: Thank you.
Rod: Thank you for patiently waiting.
Rod: The standard voltage for the tv is 60Hz.
Rod: And it can support up to 120Hz.
You: So it's not always running at 120Hz?
Rod: The standard for the U.S. is 60Hz, so it's not always 120Hz.
You: When does it use 120Hz? Doesn't it seem a bit misleading to sell this TV with consistent 120Hz if it is advertised as a 120Hz unit?
Rod: Ok. Are you pertaining for the refresh rate?
You: Yes.
Rod: I see. Because the voltage and refresh rate are measured in Hz.
Rod: Sorry for the misunderstanding.
You: How do TVs that always run in 120Hz differ?
Rod: Let me check that again for you. Please give me a minute or two.
You: Sure
Rod: Thank you.
You: Sure
Rod: Yes. You can always run your Tv in 120HZ refresh rate, just go to Menu>Picture>PictureOptions> Then, set Digital Noise Filter and MPEG Noise filter to High.
You: How does this make it 120Hz?
Rod: Because it is the highest refresh rate for your tv.
Rod: That is why it advertised as 120Hz.
You: Interesting...so this would be the same as buying the UN40EH6000?
Rod: I see.
Rod: So, are you planning to get UN40EH6000 also?
You:
Well, I want REAL 120Hz refresh rate
You: So should I keep the 6030, or get a 6000?
Rod: Ok. It's up to you. If you want much better viewing experience, go for UN40EH6000.
You: Why does that one have a better viewing experience?
Rod: Actually, the UN40EH6030F has Clear Motion Rate of 240. It means that you will experience sharp picture quality, even when you are watching fast-moving images like sports or action movies.
