Originally Posted by bewlaybrothers
HDMI black level is inoperative in Movie Mode because IIRC the set is regulating the video levels at their widest. I think this is optimal based on many different settings I've tried.
As for Film Mode, it will only function if you're using an -i / interlaced signal like 1080i. This is my visual preference over Samsung's AMP because I think it allows more consistent de-interlacing by the set and better frame pulldown, so I set my blu-ray player to it also. If you switch to most antenna or cable/satellite HD you'll likely notice Film Mode enabled there since those sources are rarely progressive.
I'd rather watch Blu-ray Disc movies at their native 1080/24p instead of converting it to 1080/60i. It can be helpful though for watching Netflix Streaming or DVDs without 2:3 pulldown on a 120Hz set (since devices like the PS3 output those in 1080/60p only, not 1080/24p).
